Rear Disc Converison
Typical rule of thumb, MC too small = soft pedal
too large = very hard pedal
What rear disc are you running?
I think flynbye.com and core3.com both have prop valves for G-bodies with rear disc.
It really depends on what calipers were used in the rear that does. Many automakers use the same valve for their drum and disc trim level cars on later model cars.
Ive done a couple of rear disc swaps using the "drum" proportioning valve. A different part number doesn't necessarily mean its internally different!
Some rear calipers use the park brake to "ratch" the pads closer to the disc to take up wear.
This ratching mechanism can seize (even on rebuilt calipers).
I had this problem on a 1980 T/A with 4wheel disc, so all the components were factory setup for 4 wheel disc. Good brakes but lower pedal.
I searched Right stuff and if the calipers are the same as the ones pictured in most of their kits they are the kind that requires the park brake to adjust the rear pad to disc clearance.
A caliper picture would be great.
If you don't have park brake cables hooked up, you should. The other option is to crawl under the car and use a pry bar on the park brake lever to adjust up the rear brakes.
These calipers were a poor design and the adjusting mechanism often seizes. It is best to use park brake cable and use them EVERYTIME you stop to help keep the mechanism from seizing.
Rear drum brakes as originally equiped on most older cars require more pressure bias than rear discs to properly balance a car during a hard stop. Lock the rears while high speed cornering, and you'll be spinning in less than a blink. Then you'll be cleaning your pants out
Note that when I originally went to the Wilwood adjustable prop valve, I had a rear axle with WS6 rear discs. I had to dial the pressure down to about 70 percent to balance the brakes right. As mentioned by others, these older OE rear discs are royal pain in the can to maintain. I always had a slider pin bind or problems getting the e-brake to back off for pad switchouts.
I eventually switched to LS1 rear discs (dialed pressure down to 60 percent) and have been happy ever since.
Also Speedway motors has a disc disc combination valve that is a must and isn't expensive, I couldn't get a good bleed with the stock combination valve as its suppose to keep pressure from bleeding off the stock rear drums.
Just some food for thought
http://www.classicperform.com/Instru...structions.pdf
