Noise after cam swap
Old Jan 25, 2014 | 12:02 PM
joshua022's Avatar
Default Noise after cam swap
Swapped a xr259hr cam in my 68 c10 with a 5.3.
And im having a whistling noise when you rev the motor or are driving down the road it gets louder with rpms.
It still does it in neutral.
It still does it with the belt removed also.
Its been a while since ive had a hotrod or a cam in something so could it be just the hardened valve train noise? I have the sewing machine noise that i was expecting but this is more of a whistle.
Thanks for any help.
Old Jan 25, 2014 | 12:17 PM
jsteele90's Avatar
seems to be a common problem with comp cams.
https://ls1tech.com/forums/generatio...am-change.html
Old Jan 25, 2014 | 01:01 PM
joshua022's Avatar
Oh gosh, shoot me...
Old Jan 25, 2014 | 04:46 PM
sweetk30's Avatar
sure its not just a since-u-was problem .
since you was in there now you happen to have a vac leak on the intake gaskets ?
just another idea to check . ya never know .
Old Jan 25, 2014 | 08:39 PM
joshua022's Avatar
Im going to do the intake gaskets to see if thats it but i really doubt it as they werent touched
Old Jan 26, 2014 | 07:28 AM
sweetk30's Avatar
you don't need to do them .
search on how to check leaking intake gasket with propane bottle.
if found bad then change them .
Old Jan 26, 2014 | 01:27 PM
joshua022's Avatar
Well it is possible as everyone in the other thread says it does it more over 2k rpms where mine does it at idle and at every rpm.
Tryin to be optimistic... Lol
Old Jan 26, 2014 | 02:22 PM
EastTnZ28's Avatar
If it runs good, turn the radio up.
Old Jan 26, 2014 | 06:39 PM
sweetk30's Avatar
as a mechanic I love customers like this
Old Jan 26, 2014 | 09:12 PM
Project GatTagO's Avatar
My bet is that it is a vacuum leak...
Andrew
Old Jan 26, 2014 | 09:52 PM
1970camaroRS's Avatar
Is it a whistle or a whine? Whistle is air noise. Whine is mechanical.
Old Jan 26, 2014 | 09:57 PM
joshua022's Avatar
Really sounds more like a whine to me
Old Feb 2, 2014 | 06:51 PM
mchicia1's Avatar
Take a video. I have the same problem as do others in that thread.
Here is Colt's new video, he just swapped his
Here are mine
I wonder if all the cores come from the same vendor.
Old Feb 2, 2014 | 07:13 PM
jsteele90's Avatar
all of us that have this whining issue need to send these threads to comp cams and see what they say, bc it is definitely not a isolated incident.
Old Feb 2, 2014 | 09:15 PM
sweetk30's Avatar
dam
makes me NOT wana do a cam swap any time soon .
I have noticed a huge trend in the aftermarket world these last few years .
" its not our problem we have never had 1 person complain " BULL FU*KIN **** A$$ HOLES
hundreds of thousands of manufactured parts and not 1 dam bad parts
get a life and work with us . not everyone on the other end of your phone is a total stupid a$$
just over 1 month ago I had a bad part in a brand new $2900.00 aftermarket kit . back and forth and finaly the tech guy sent me another replacement item . and what do you think happened ? ? ? it fit like a glove and no more problems . the place still never come out and said it was a bad item and it was there problem . ha ha ha ha ha
Old Feb 5, 2014 | 12:25 PM
joshua022's Avatar
Originally Posted by sweetk30
dam
Im thinking of pulling the heads and changing the lifters to see if that helps, because my cam was used, and the guy I got it from swears he never had any whining noise from it. So im thinking maybe a lifter got spun around and isn't sitting right.
Might can talk the wife into some CNC'd heads too! just tell her it might help..
Old Feb 5, 2014 | 03:27 PM
Hart_Rod's Avatar
in.....
Old Feb 5, 2014 | 06:57 PM
joshua022's Avatar
Here is my video
