gbody dbw
Old Feb 1, 2014 | 03:55 PM
delreyss's Avatar
Default gbody dbw
I have a 86 monte ss with a 5.3. How have you modified the gas pedal to fit any one have pictures or advice
Old Feb 1, 2014 | 05:02 PM
HexenLord's Avatar
Depends on which gas pedal. Certain years use different pedals. Because I had an 06, I had to use a specific pedal/TAC module.
Old Feb 1, 2014 | 06:00 PM
spacemanspif's Avatar
x2.
I had a truck pedal that was adjustable so it was a lot more complicated than most. Just cut off the pedal and welded part of the old Monte pedal to what was left.
Same basic recipe for all pedals though; bolt the pedal to the firewall and weld on the old one so the placement is close to stock.
Old Feb 2, 2014 | 01:43 AM
garys 68's Avatar
Not a G body specifically. But it's pretty easy to shorten the truck pedal.
Old Feb 2, 2014 | 12:10 PM
BOXCHEV's Avatar
I've read that vette pedal works pretty good.
Old Feb 2, 2014 | 12:39 PM
delreyss's Avatar
I'm thinking about cutting the stock pedal and weld it to the dbw pedal
Old Feb 2, 2014 | 12:40 PM
delreyss's Avatar
I'll send you a picture on how it came out and some fitment pics
Old Feb 2, 2014 | 02:53 PM
BOXCHEV's Avatar
Scroll down to post #4
https://ls1tech.com/forums/conversio...lq4-4l80e.html
Old Feb 2, 2014 | 03:10 PM
locrzn's Avatar
I bought the Locar pedal and module for about 400.00. Its an easy install and looks great under the dash. Nice and easy driving till you to put the pedal to the metal.
Old Feb 2, 2014 | 03:11 PM
locrzn's Avatar
I used the Lokar pedal and module. Easy install and clean looking under the dash.
Old Feb 3, 2014 | 06:14 PM
delreyss's Avatar
Originally Posted by BOXCHEV
That what I'm planning on doing I'll post some pictures tomorrow. I'll weld it up tonight
Old Feb 4, 2014 | 07:51 AM
ig109's Avatar
That's exactly what I did.. mounted the DBW pedal and cut the stock pedal off.. welded it to the truck DBW pedal.. check for full travel with scan tool.. Done
Old Feb 4, 2014 | 09:33 AM
99VetteFRC's Avatar
I used the truck pedal that came with my 03 engine. I cut about 6" out and welded back together. Been in the car for 2 years and works perfect.
Old Feb 5, 2014 | 06:31 PM
loweredd's Avatar
LOL! Thanks. I just saw this and was going to post pictures. Thanks for picking up my slack.
I tacked mine for mock up a few times just to get it right. Seems fine where I ended up with it.
Old Apr 29, 2014 | 08:59 AM
mk1ofmnm's Avatar
Just curious if you got this done?
Old Apr 29, 2014 | 09:50 AM
chuckrv6's Avatar
I used the 2008 impala ss pedal rebent in the vise works with 2009 tahoe ly2 harnass-e38. Chuck
Old Nov 2, 2022 | 11:28 PM
queezy's Avatar
Default Gbody LS Swap with Impala pedal - Help needed
Hi,
this is my 1sr post here and my 1st LS swap. I’ve gotten to wiring and I’m having trouble with my gas pedal. I have a Gen 3 2006 5.3 with tac module and wiring. I saw that the Gen 4 could use the impala pedal after being repined. Does anyone have any experience with this or know how to get this tac to work with the impala pedal?
Old Nov 3, 2022 | 04:39 AM
Jimbo1367's Avatar
I realize this isn’t necessary what you were asking for, but Holley now makes DBW brackets for popular LS swapped vehicles .
They are intended for using the LS LS3 Corvette pedal. They are on sale so I bought one (70-80 Fbody) and it fit my car perfectly. They’re powder coated too. Win-win.
Old Nov 3, 2022 | 06:25 AM
Old Buzzard's Avatar
This thread is 8 yrs old. Suggest you make a new thread.
Old Nov 6, 2022 | 12:13 PM
Project GatTagO's Avatar
This might help:
https://www.holley.com/products/engi.../parts/145-140
Andrew
