Lm7 swap into 83 chevy short bed.
#41
update
Well turbo showed up,head studs should be here some time within the next few days,also ordered all the hot side pipes and bends, should start with hot side fab friday when i get back to shop,also have a waste gate on its way as well.will post pics soon. what size piping are guys running for cold side? to and from intercooler??
#43
#45
Maf sensor
I got turbo hot side pretty much done with.i was going to start getting intercooler stuff figured out,and have a question,where are guys installing the maf, intake to engine with boost,or on intake pre trubo,pre boost? my thoughts are with boost,but have no idea.
#46
update
got waste gate all mounted up,hot side is pretty much done,have to run the turbo feed and drain lines. will post pics of the waste gate and were iam at with the engine.its pretty close to stuffing in. going to get an intercooler tomorrow and start fabbin that this week.
#47
#48
#49
fuel
i have a question as in i will be running a boost referenced regulator with #60 ilb injectors with the stock rails could some one let me know if they have accomplished this and how they did it so i have a general idea of how to go about this as in the routing and what not. thanks
#52
Trannsmission
So since i cant find a 4l80, i got my hands on a TH 400 out of a motor home, I will get a rebuild kit for it and give it a refresh. The question i have is what exactly will i need to make it work with the current flex plate? or do i need to get a different plate? i have read all over but nothing i read is giving me the confidence in what i will need for it. also engine is a 2005,l33(not an lm7) like the thread says. with a dished flex plate. anybody please feel free to give me some pointers on this. iam getting closer on putting the thing in... just minor set backs... like this. are kicking my ***. thanks
#53
Flywheel spacer or new flex plate
Still have a question on the tranns, i got the 400 all dissassembled and starting to go back together,was wondering as to the spacer, hues has one that says its for 99-04 ls style engines, but mine is an 05 l33, can anyone let me know what to do here?? Thanks
#55
update
Got tranns all together, will be running a 3k stall,i used the spacer that you drive into the flex plate,still have to elongate the holes a tad but other than that she should be good,on other notes,the BOV , Fuel psi regulator and fuel pump showed up, went with a walbro 255, will eventually run two, but not going to put in and be running a bunch of power right away. also got all intercooler piping in and should be on target to pull engine this upcoming weekend if all goes right.Also got fuel cell all fabbed up and installed,had to install in bed as to the truck being to low.will post some pics this week.
#56
block heater
so i went to put the engine mounts on the engine and found that the drivers side hit the block heater, so i pulled the heater out,question is does anyone know of a plug that is threaded that takes care of the block heater port??
#57
injectors
ok so i got the truck running and was curious as to how much boost you can run on the stock injectors,just for driving around town and not getting into it.?? untill i get my 80s?.....
#58
How hard is it to find 4x4 versions of the 4l80e in your area???
2x4 versions around here are scarce as hens teeth...I have converted 3 of the 4x's over for my projects over the years...
I hope to see some running pictures of this thing...
I have an '86 C-30 dually LQ4/4l80e I built back in '08...I'd like to turbo it soon...
#59
