LSeX Boosted Notchback. 5.3,TH400, etc
Old 01-05-2015, 11:47 AM
  #81
FrossB's Avatar
Nothing really noteworthy anyway! haha
I dropped the heads off a few days ago to the cleaned up and valvesprings installed.
Got a complete fuel system (minus injectors) for Christmas. Slowly acquiring parts. Its struggling to stay above 0 degree temps where I live so im not super motivated to go out to the non-heated garage! Also, two feet of snow on the ground puts a hamper on my life lol
That being said, my birthday is in a week and the misses always hooks me up with car parts. And tax time is right around the corner to that'll help too! Just need some warmer weather!
Old 01-12-2015, 07:42 PM
  #82
WEIGHTMAN's Avatar
what rad did you have mocked in the car
Old 01-12-2015, 07:46 PM
  #83
FrossB's Avatar
It is an F Body LT1 rad. I will eventually upgrade but I practically got it for free
Old 01-13-2015, 01:35 PM
  #84
FrossB's Avatar
Ordered an AJE trans crossmember for the TH400, a battery relocation kit and some welding wire. Now I can start fabbing up my hotsite.
Tax time will get me a converter, injectors and a harness!
Old 01-13-2015, 04:04 PM
  #85
WEIGHTMAN's Avatar
you gonna stick with the 3.55 or drop lower, i have 3.31 and am debating to go 3.73 or 3.55
Old 01-13-2015, 04:18 PM
  #86
FrossB's Avatar
For the time being I am going to run the stock 8.8 rear gear (which I believe is like a 2.9x). But once the car is running smoothly I will upgrade, probably to a 3.23.
3.55 would be my absolute max for being a turbo auto car tho
Old 01-13-2015, 04:47 PM
  #87
WEIGHTMAN's Avatar
im gonna run a 4l80e so i wonder if i could get away with more gear
im following your build, good luck
Old 01-13-2015, 04:50 PM
  #88
FrossB's Avatar
I would think you would be fine with more gear since you have an overdrive trans.
Old 01-14-2015, 01:21 PM
  #89
87lsttop's Avatar
Nice car, looks exactly like the one I just picked up. I got a turbo t top that I swapped a few years back with a Upr 5.0 k member, just built mounts. Its got a tc78 bone stock 5.3l other than btr valve springs and ls6 cam. On 10 lbs it put down 544 and 580. Took it to the track and trapped 129.5 all night. It was on skis so I only ran 11.30s. With the 400 look at a 3.27 gear, with of u can get away with steeper. I was at 6200 on the big end. So def stay down
Old 01-14-2015, 01:27 PM
  #90
FrossB's Avatar
Im hoping to hit 500whp on E85 without going to high on boost (mainly because of the LS6 springs). Im going to be running a 275/60 tire. And I was actually swinging to a 3.27 rear gear for the top end.
Impressive numbers tho man!
Old 02-03-2015, 04:56 PM
  #91
FrossB's Avatar
Hurry up IRS and give me my money!!!
That being said, waiting to pull the trigger on a harness, injectors, and some smaller random parts. The guy that was cleaning up my heads and installing my valve springs still has them! Its been over a month. SHOULD have them this weekend then I can put the engine together and toss it in the car and hopefully start fabbing up the hotside!
Old 02-10-2015, 12:29 PM
  #92
FrossB's Avatar
Update:
Ordered a BP Automotive harness. Bill is the man!
Also got my turbo oil line kit, and some couplers.
Spent about 14 straight hours in the garage yesterday putting the engine back together, cleaning and painting parts, installing my turbo drain bung, and putting the engine back in the car. Next up is to start fabbing up the hotside.
A few pics
Turbo drain location. It was a close fit. I have less than a centimeter of room until the AN fitting till hit the balancer :/
In the bay. SOOO DARK!
Old 03-10-2015, 01:21 PM
  #93
FrossB's Avatar
Decent little update. Finally got a decent break in the weather here in western Nebraska and had a 60 degree weekend. Took advantage of it and fabbed up my hotside. Damn near took me longer to make a bracket for the mergepipe/flange so I could use it for mockup.
Don't look close at the welds. They aren't purty..just functional
High-Temp Primed and painted it. Looks a little less shitty
TIGHT SPACES!!!! Kinda of thinking about getting a smaller framed turbo. Is the On3 76mm or 7875 (or whatever) smaller framed than the GT45?
Looks alright. Awfully close to that alternator.
Nice view of the new radiator. Im going to notch out the support a little to tuck that radiator in a little better.
Old 03-10-2015, 04:38 PM
  #94
quick85vet's Avatar
Looking good! Car should be a beast!
Old 03-10-2015, 04:40 PM
  #95
FrossB's Avatar
Thanks man! Yea it should be fun for sure. Hopefully ill get to drive it this summer!
Old 03-10-2015, 04:51 PM
  #96
RedRocketZ28's Avatar
The on3 turbo will be smaller. Looks good man.
Old 03-10-2015, 04:57 PM
  #97
FrossB's Avatar
Thanks! I found a picture comparing the GT45 to a On3 76mm and yes the GT45 turbine side is probably 1.5x as large. That's good news for me being that the turbine on the GT45 is what is causing me issues with clearances
Old 03-16-2015, 09:32 AM
  #98
FrossB's Avatar
Always wrap it up kids!
Old 03-17-2015, 10:55 AM
  #99
FrossB's Avatar
Ordered some 80# injectors! Id say after a few weekends of work I should be able to fire this beast up!
Old 03-18-2015, 12:27 PM
  #100
FrossB's Avatar
Did some downpipe fabbing...
I REALLLLLY need to get a better welder
Tight squeeze. I really thought I was going to have more room than this haha
Exit location
Quick Reply: LSeX Boosted Notchback. 5.3,TH400, etc
