Made some progress on the car...
Finished up the diff rebuild and flange adapter plate.
I will clearance the subframe some and weld another plate across the bottom.
Here's the 5" exhaust vs my old 3" hahaha
Worked some on my crossover setup too
Front brakes showed up today, still need rotors.
I saw this picture online comparing gen 4 bottom end to gen 3 and I quickly decided to swap in the aluminum 5.3 I have.
Here's how it looks so far with the catch can in the corner too.
Next up I'm building the trans and setting up a trans pump to keep the gears cool. Still need to order a driveshaft, front hubs/rotors, and small things.
Thanks! Just got all my 5 lug and brake parts on. Still need to finalize the caliper bracket and get proper quality rotors. Also ordered a set of work equips redrilled to 5x120 and the centerbore enlarged to 72.5mm. Next step is building the trans with a Viper main shaft too, if I can manage to find one not looking to good so far.
Pushed the car out to clean it up and weld up the booster holes in the firewall.
Finished rebuilding the t56, but diff is giving me trouble and has play even after reshimming it....
