Alternator with holley HP EFI
just install a resistor (approx 60-250 ohm, 1/2 watt) from ign to pin b on the alt connector.
This does two things
1 it excites the alt to charge and
2 it limits current when the key is on but the alt is not spinning as the regulator inside
the alt shorts to ground.
Without the resistor you will burn up the regulator inside the alt. Steve
Would anyone have a diagram of some sort?
