S13 LS1 swap wiring help
2nd. The chase bays harness appears to tie into the factory fuse box at the grey/brown plugs. This means that switched power, batt power, fuel pump, etc comes from the fuse box into the CB harness. Get an FSM and unplug the chase bays **** from the grey/brown plugs. Check for batt, switched, etc at the plugs and fuse box first then making sure the fuse box relays are ok. The CB harness probably uses the stock fuel pump relay in the box. You should be able to trip this yourself by with the relay out to make sure the pump works.
If EVERYTHING at the fuse box that is oem Nissan works fine then starts checking the CB harness. Now a quick check on Zilvia shows a **** ton of problems with CB harnesses so odds are your problems are there but by checking out the oem stuff first you can eleminate problems on your end.
READ THE FSM. The first pages of the fsm go into detail about starting circuit and power supply routing. A multi meter and noid light will do wonders.
