ls1 guru needed cant get her started
Old May 29, 2014 | 08:01 PM
  #41
drift donkey's Avatar
Could it be a bad pcm??
Old May 29, 2014 | 10:07 PM
  #42
1FastBrick's Avatar
Originally Posted by drift donkey
So I have the correct injectors In and the engine will idle, but #1 banks timing is still off! What would cause this??? Please help!!!
How do you know #1 banks timing is off???
A Bad PCM is rare. Usually when the PCM is Bad, either an injector signal is stuck on or off or the coil signal is either stuck on or off.
If you have Spark and Fuel most likely it's something mechanical at this point.
Old May 30, 2014 | 07:28 AM
  #43
oldgoat69's Avatar
Did you verify that you have the coils in the correct sequence. It is possible that you have a couple of the connectors switched around. If it is indeed a firing order issue.
Old May 30, 2014 | 10:58 AM
  #44
Thanks oldgoat69! U are the winner. I had the freaken harness for #1's coils backwards.
I swapped it and she runs like a top.
Big thank u to everybody that helped me with this. I owe u guys some beers!!
