4L60E question
Old Jun 5, 2014 | 07:12 AM
rquad's Avatar
Default 4L60E question
Can anyone identify the electrical connector below? It hangs off the 4L60E on the passenger side, just back of the bellhousing...
This is on a factory LS2/4L60E combo (GTO) with the full factory wiring harness. There were three other connectors on the harness that went to the tranny, but I didn't see anything for this one.
Old Jun 5, 2014 | 07:40 AM
mille_3's Avatar
That looks like an o2 sensor plug
Old Jun 5, 2014 | 07:56 AM
oldgoat69's Avatar
Agreed, should be another on the other side, maybe not in the trans harness.
Old Jun 5, 2014 | 09:19 AM
EFIHARNESS's Avatar
Yes, it is an O2 sensor connector. Steve
Old Jun 5, 2014 | 09:40 AM
rquad's Avatar
Well, that's interesting because there are two other connectors (one on each side) that are orange/black, have four leads, but are inline instead of square. I thought these were the O2 sensors since there is one on each side. What are the orange/black connectors if the blue/white is O2.
Old Jun 5, 2014 | 09:46 AM
rquad's Avatar
Alright, so never mind on the above question. I search RockAuto for GTO parts, and now I see that this setup has two each of upstream and downstream O2 sensors. The square ones are the upstream and the black/orange ones are the downstream.
So, now the question becomes which ones do I tune out? I assume I get rid of the upstream?
Old Jun 5, 2014 | 10:25 AM
nicke's Avatar
Nope, you get rid of the downstream, which only verify operation of the cats.
-Nick
Old Jun 5, 2014 | 11:25 AM
Oscar Will's Avatar
...what Nick said
Old Jun 5, 2014 | 11:54 AM
gofastwclass's Avatar
The rear O2 sensors will be listed in the software as "Bank 1, sensor 2" and "Bank 2, sensor 2."
Old Jun 5, 2014 | 12:18 PM
rquad's Avatar
Awesome.
I hope the O2 sensors come with some long cords. Those upstream connectors are pretty far away from the bungs at the end of my long tube headers.
Old Jun 5, 2014 | 02:39 PM
superdave84's Avatar
Awesome.
You can buy extended adapters that lengthen them. No need to cut or splice anything, just plug in both ends and you're done.
Old Jun 5, 2014 | 11:16 PM
EFIHARNESS's Avatar
all of the above answers are correct. One more thing, be sure you connect bank 1 sensor 1 to the odd side,and bank 2 sensor 1 to the even side, If backwards you will have problems. Steve
Old Jun 6, 2014 | 06:34 AM
rquad's Avatar
You guys are great. Tons of info. Just what I needed.
