Sonoma Towing with LS6
Old Jun 10, 2014 | 01:13 PM
SonomaGTLS6's Avatar
Default Sonoma Towing with LS6
Hey all,
The LS6 swap into my 99 Sonoma has been running great so far (~2000 miles). Everything is functional except ABS at this point, but that will be worked out later. Reason for this post is I will be towing a camper this weekend that will probably be around 3100lbs but am currently running the stock timing and fuel from the 2003 Z06 and I assume towing was never considered for a vette tune. My question is whether or not I should play around with timing or other settings (I have HPTuners) or just rely on knock sensing to do the work? I don't plan on trying to break any land speed records and have considered lowering the torque management criteria to limit stress on the driveline, but am a bit apprehensive about playing with timing. Anyone here have experience with towing using an F-body or Vette tune?
Old Jun 10, 2014 | 08:27 PM
rpturbo's Avatar
I don't have a base vette tune, but I did haul a car trailer with my LS swap. I just figured my low octane table would work if it got into KR. Just drive like you have a brain, you know what I mean.
Old Jun 10, 2014 | 09:41 PM
sprech's Avatar
Well, as far as a Corvette towing something is concerned...
Old Jun 11, 2014 | 05:46 AM
But the colors match, and that's the most important thing!
Thanks for the feedback guys...probably won't change anything now.
Old Jun 11, 2014 | 08:30 PM
S10xGN's Avatar
WTF? Bat boat?
Old Jun 11, 2014 | 09:30 PM
sprech's Avatar
I don't know, but that pic was taken in Vegas and the plates were Florida.
Old Jun 17, 2014 | 01:17 PM
Just a follow-up...no issues to note during the 300 mile round trip this weekend! Only downside is I got just above 10 mpg running 65-70 mph. Didn't matter whether it was in 4th or 5th gear. Will likely just draft semi's at 60 mph in 4th gear in the future to save the trans. Truck started and stopped great! Just lots of wind resistance with the trailer behind.
Old Jun 18, 2014 | 04:10 PM
rpturbo's Avatar
Thats what I am talking about! I would imagine if you slowed down, you would have done a little better, but probably not much. Like you said, there is such a wind resistance difference between the 2, mpgs won't likely change by much.
