Pro touring 1967 Nova SS LS3 416 build
I haven't posted much, but I have done a lot of research on here and I give thanks to this site for having the information I needed to feel confident upon doing an LS swap in my car. To pay back, I'm sharing my progress on my swap with lots of pics.
I decided to do a mild build with my car, but try and keep it simple. I recently installed a new front clip before doing my swap. Here's the info on it all...
Car: 1967 Nova SS
-TCI pro-touring front clip with RideTech adj. coilovers, drop spindles, Wilwood brakes with 12" drilled/slotted rotors.
-Ford 9" with 4.11 gears
-Engine built by Mullenix Racing Engines (everything is brand new) LS3 416ci stroker (4.070" bore x 4" stroke), 255 71cc CNC Ported Heads, Custom Grind Lunati Cam with .650 lift, Lunati H-Beam Forged Rods, Lunati Forged Crank, Ross Forged Pistons, LS3 Intake, Holley 90mm Cable Throttle Body, Holley Fuel Rails, TCI Headers, Holley Valve Covers, LS7 Lifters, Melling Oil Pump, F-body Oil Pan, 42 lb. Injectors, Corvette Water Pump & Blancer, and Truck Alternator. Lokar Throttle Cable, Lokar dipstick, PSI Conversion Harness and 12200411 PCM.
-Trans built locally: Built 4L60E with Sonnax Smart Tech Input Drum, Sonnax 300mm Input shaft, Transgo full race shift kit, Sun Shell (the beast), 5 gear rear planet. Lokar Trans dipstick.
Fuel System- 20 gallon Rhodes Race Cars aluminum fuel cell with sump and baffle around sump. Inline Holley fuel pump with Holley fuel filters. -8 an feed line and return line.
Upcoming mods: Mini-tub with rear disc brakes, TCI rear suspension with RideTech coilover, and then repaint.
Hope you guys enjoy my build thread! I also run the page on instagram called ModernDayHotRods Check it out!!!
Before all the new goodies.
The tear down begins.
New Por15 Chassis Paint
TCI pro-touring front clip arrived.
Por15 Chassis Paint.
Front Clip is done and installed.
Engine is being built.
Checking rod bolt stretch
Engine is complete and shipped. The excitement starts.
Engine and Trans are mated and put in.
Some engine **** now that she's all in and ready to start
Now she's all together and idling before a dyno tune (click each one to be lead to the video)
Check out my YouTube idling compilation of my car
Car: 1967 Nova SS
