LSA/Grand National Conversion
I did the notch to the seam. I'm probably moving to the Nitto tires that run small.The 335/30/18 Nitto should not be any larger than the Bridgestone 325/30/19 I already had on the car. The pic below is of the 325/30-19. If the Nitto on my 18x11 wheels with 5-3/8 backspacing do not fit, I will go to the Mickey Thompson 305/35-18. When the car is on the ground, they fit just inside the rolled lips and don't touch.
5.5 back spacing.
The fit is perfect with 305/35-18 MT
The front is 18x8.5 with 4.5-4.75 backspacing(I don't remember which one)
We have a BW4472 transfer case built with a Mark Williams 32 spline input shaft to mate up to the 4L80E(4wd tail on my existing 4L80E)
The front pumpkin is from a Typhoon like the transfer case. The front suspension is c5 corvette with the c5 rear knuckles up front. The upper arm will need to be custom fabbed due to coil over location. It will be another year project for me.
What is the pulley setup for the SC?
What are IAT pre-TB from turbo to SC and IAT 2 post SC boost into the motor?
If you would share both low boost and high boost numbers that would be great for IAT2.
Thanks!
