LSA/Grand National Conversion
Here are some pics. I have about 100 shake down miles so far with no issues. I have a boost controller that switches from 783rwhp/778rwtq to 965rwhp/931rwtq.
Holy God it's in low boost at all times.
Meanwhile, we have an R&D 86 regal that we are testing an AWD system on to transfer to this car.
Icing on the cake.You planning on any heat blankets for those turbos? With that exhaust turbine so close to the rear inlet I'd be concerned about IATs and/or melting the adjacent filter.
Men monitoring the intake temp. on the last dyno pulls with high boost the intake temp was 120. A little over kill on the water to air intercoolers for a safe measure.
I'll look into the Hooker Aerochambers and the Dynomax Super Turbos. I'll keep you posted on the mufflers and start getting videos together. I have one dyno pull on video on low boost. I'll get that posted later today when I get home.
Take a look at the Magnaflow mufflers. They are very tame at idle and cruising and get pretty loud under load. They make some longer versions too that would make the low load noise even less.
To be honest. I think low boost set at 12-14lbs and high boost set at 18-20 would be plenty. It's just too much for street use.
