What throttle cable for fox swap?
Old Jul 5, 2014 | 10:49 AM
boostnut's Avatar
Default What throttle cable for fox swap?
Wrapping up a swap in a 95 mustang & don't know what to use for a throttle cable. Ideally I would like to find one that fits the firewall (2 bolt mount) correctly and modify the ends as needed.
What are you fox guys using? A cable from a 95 f-150 inline 6 looks like it may work but before I order one I thought I should ask here.
Old Jul 5, 2014 | 01:58 PM
Bowtiedford's Avatar
on my fox body I used the stock factory one
Old Jul 5, 2014 | 02:00 PM
Old Jul 6, 2014 | 08:49 PM
boostnut's Avatar
Hmmm, my stock cable is nowhere near that long. Gonna try one for a 92/93 F series pickup. Should be here in a couple days.
Ref. ATP Y614
Old Jul 6, 2014 | 08:52 PM
I'm surprised it wouldnt be as there both 5.0's and t body was on the same side and location.
Old Jul 9, 2014 | 08:24 PM
boostnut's Avatar
Got the f-150 cable today, no deal, doesn't work. Going to mod the f- body cable with the mustang firewall fitting like I should have done in the first place.
Old Jul 10, 2014 | 01:59 PM
5.0 LsX's Avatar
stock fox cable, universal lokar and or lsx universal cable with the oem firewall parts modded, all worked great for me
Old Jul 11, 2014 | 09:00 AM
1bad03snake's Avatar
I used a factory 5.0 throttle cable I drilled a hole in the casting on my old ls6 intake and tightened the metal table down with a small bolt/nut
Old Jul 11, 2014 | 09:03 AM
boostnut's Avatar
There must have been a change to the cable for 1995. My stock 5.0 cable is about 4" short.
Old Jul 12, 2014 | 09:44 PM
matt99's Avatar
The lokar cable is cut to fit and it's not very pricey and looks nice as well.
Old Jul 13, 2014 | 12:37 PM
jwcarguy's Avatar
X2 on the Lokar cable
Old Jul 15, 2014 | 07:38 PM
sick_46's Avatar
I just did a swap on my 97 mustang. it had the v6 and that throttle cable looked like it would work perfectly. I am using dbw so I didn't use it but I did take it out after the motor was in just so I could see how it would work if I ever convert to cable
Old Jun 10, 2015 | 10:52 AM
tschellinger2's Avatar
What length was the universal lokar throttle cable you guys were running for the fox?
Old Jun 12, 2015 | 11:17 AM
FrossB's Avatar
Lokar knockoff off ebay here. I think it is 40" and cut to fit.
Old Jun 12, 2015 | 11:43 AM
booboo37's Avatar
what k-member you guys using and any problems ?
Old Jun 22, 2018 | 11:14 PM
blackfire93's Avatar
Used an S10 cable from the junkyard on my Zephyr. Opened hole in firewall just a tad. Plugged right into the hole and was the perfect length. No modification needed to the cable. Using a truck intake.
