Porsche 944 : Turbo 5.3 build
Old 07-18-2014, 05:36 PM
DW SD's Avatar
The truck manifolds are much wider than the corvette or camaro, as I understand.
Worth measuring. The truck manifolds were like 5" wider (outside of each outlet) than the corvette. They didn't fit my frame rails @ 27" between.
should be easy enough to measure?
Doug
Old 07-18-2014, 05:39 PM
Sentronix's Avatar
Indeed, once I get the car here it will be no problem. If some massaging is in order, then it will be done. I can also flip the manifolds and make them point upward I believe.
Old 07-18-2014, 05:55 PM
DW SD's Avatar
I think you can mill the face a bit to change the angle, too. Still, I wouldn't count on that too much.
Doug
Old 07-18-2014, 05:59 PM
Sentronix's Avatar
I have read that they fit with minimal interference when fitted the correct way so hopefully we are good. Thanks for the heads up
Old 07-20-2014, 09:00 PM
autocomman's Avatar
I MIG'd my manifolds and I couldn't believe how easily they welded! Lookin forward to the progress on this project
Old 07-28-2014, 11:20 PM
Sentronix's Avatar
Well things took a turn for the weird and I ended up buying a whole Corvette T56 Drivetrain. It included everything from the engine back. The car will now be AMAZING with the 6 speed. I just have to work on mounting it. Timeline for the whole build is one month! Anyone have experience with shortening the torque tube?
Old 07-29-2014, 07:22 AM
Sparkydog's Avatar
If you worked on it full time for 1 month that would still be an aggressive schedule IMO. I think there are 1 or 2 guys on the 944hybrids forum that have either direct experience with the Corvette transaxle/TT or at least thought about it. They may be able to help with shortening the TT. Good luck with your build!
Old 07-29-2014, 01:40 PM
Sentronix's Avatar
I know it's ambitious but I really hope to AT LEAST have the drivetrain in the car within the next couple weeks.
Old 07-29-2014, 03:24 PM
autocomman's Avatar
Is this how they normally so 944 swaps? Just dump the whole 944 torque tube and trans?
Mark
Old 07-29-2014, 03:28 PM
Sentronix's Avatar
Mark
No I believe this will be one of the only if not the only V8 944 with a t56 transaxle
Old 07-30-2014, 11:04 PM
Sentronix's Avatar
Well I got the motor and front crossmember out, next I will do the torque tube and rear suspension removal. Then I can start mocking up the trans!
Old 07-31-2014, 10:54 PM
  #32
Sentronix's Avatar
I am replacing the stock torsion bar rear suspension with coilovers since I will need to trim the torsion bar housing to fit the transmission. I got the coilovers in today from ground control. They look great! Stock strut pictured for comparison.
Old 08-01-2014, 12:51 AM
  #33
WheelsUp84z's Avatar
shortening the TT would be fairly straight forward, there is a driveshaft inside that's aluminum, Just shorten that the same amount, as well as the shifter linkage.
Old 08-01-2014, 09:19 AM
  #34
merim123's Avatar
i was searching last night on this, this is an interesting approach for this conversion. Looks like there is a lot more going on inside the torque tube but as you say, maybe it is just shortening the driveshaft and shifter linkage
http://forums.corvetteforum.com/c5-t...with-pics.html
http://www.clarks-garage.com/shop-manual/trans-05.htm
https://ls1tech.com/forums/14982219-post21.html
Old 08-01-2014, 09:46 AM
  #35
Sentronix's Avatar
Well I actually got good news regarding the torque tube. It does not need to be shortened after all. So I am very happy about that.
Old 08-05-2014, 04:59 PM
  #36
Sentronix's Avatar
I ordered my turbo today. Largest S366 I could find. This thing is going to be a tire killer.
Old 08-07-2014, 11:05 PM
  #37
Sentronix's Avatar
Well I got the motor in, now it's time for some serious fabrication
I also got my new TIG welder. Watercooled HTP Invertig 221. I'm very excited!
Old 08-08-2014, 10:18 AM
  #38
Project GatTagO's Avatar
Received 1,441 Likes on 909 Posts
Great build!
Andrew
Old 08-08-2014, 11:23 AM
  #39
merim123's Avatar
curious...why did you go w htp vs miller or lincoln?
Old 08-08-2014, 11:40 AM
  #40
DW SD's Avatar
Looks like those exhaust manifolds will be a tight fit in their upward orientation. Is that the case?
Doug
Quick Reply: Porsche 944 : Turbo 5.3 build
