Help Can't get scanner to link up
Old Jul 30, 2014 | 10:41 PM
fillpot's Avatar
Default Help Can't get scanner to link up
Guys have a 69 Camaro with a Trailblazer SS LS2 and 4l70e, changed the camshaft and intake and in the process also put the battery in the trunk, now got a few codes and can't get my snap on scanner to log on, all the grounds etc seem good any ideas, this has got me in a bind, I now that if the scanner want log on my tunners software is sure not. THANKS!
Old Jul 31, 2014 | 07:41 AM
HeavyMetl's Avatar
I used to have a few problems, thought my grounds were good too.
Pin 5 on the OBDII port needs to be on a common ground with the PCM. Once I changed that instead of just grounding to the body my connection problems were solved. Of course, you're problem might be different.
Old Jul 31, 2014 | 06:13 PM
99MUSTANG5.3L's Avatar
Had the same issue with my scanner and grounding pin 5 solved it.
Old Jul 31, 2014 | 10:44 PM
fillpot's Avatar
Thanks guy's, now trying not to sound like a complete idiot but is pin 5 numbered on the connector, and do I need to ground this with the other pcm grounds, or separate, to chassis, body,etc man been a long couple of days with this problem just about burned lol, oh btw john at speartech done a rewire on the harness a couple of years back if this helps, I called him today a left a message maybe i'll here back from him tomorrow! THANKS!
Old Jul 31, 2014 | 11:47 PM
1FastBrick's Avatar
Here you go
Old Aug 1, 2014 | 12:29 AM
fillpot's Avatar
Thanks brother big help, I'll check it out tomorrow. THANKS!
Old Aug 1, 2014 | 07:10 AM
gofastwclass's Avatar
I believe the TrailBlazer SS engine and PCM are CAN Bus. This means the previous pinout won't help you since the supplied graphic only lists OBDII (J1850 to the engineering types). If you look at my stolen drawing, there are two required pins for CAN bus high and low (6 and 14 respectively). This eliminates the need for pin 2, so don't be alarmed if there is no pin 2 on your harness.
Old Aug 1, 2014 | 06:07 PM
oldgoat69's Avatar
Ditto! I went through but for an entirely different reason. Can-Bus not LAN.
Old Aug 2, 2014 | 11:28 AM
V8Rumble's Avatar
Great, another thing to check/keep track of... So how likely is it that my 2007/2008 L92 uses the CAN bus, rather than OBD-II?? (I'm guessing that it's fairly likely, huh?)
Old Aug 3, 2014 | 03:18 PM
fillpot's Avatar
Well guy's about throw in the towel on this one everything seems to check out as far as grounds, power wires etc, talked to john at speartech Friday and he said I would find it but no luck, im going to see if I can send it back to him to get checked out, any suggestions. THANKS!
Old Aug 3, 2014 | 10:30 PM
fillpot's Avatar
Oh btw guy's may just buy a new harness, always hated the way this one was built because of no place to mount the pcm but around the engine bay, fender well etc,also was looking at the holly efi stuff any input on this. THANKS!
Old Aug 4, 2014 | 03:21 AM
branndonw's Avatar
At the OBD2 connector, verify that you have ground on pins 5 and 6 and battery positive voltage on pin 16. At the TCM connector, verify that you have Accessory/Ignition voltage on Pin 11 (YE), Ignition voltage on Pin 31 (PK), B+ voltage on Pin 32 (OG), and Ground on Pin 49 (BK).
If all that tests good, check continuity on the High Speed GMLAN wires. The High Speed GMLAN wires are routed from the OBD2 port to the TCM and then out to the ECM.
Check continuity between the following points:
Pin 6 of the OBD2 Port and pin 7 (D-BU) of the TCM.
Pin 14 of the OBD2 Port and Pin 6 (L-BU) of the TCM.
Pin 37 (TN) of the TCM and Pin 2 (TN) of the Blue ECM Connector if its a 2006 w/E40 ECM or Pin 33 (TN) of the Gray ECM connector if its a 07-09 w/ E67 ECM.
Pin 38 (TN/WH) of the TCM and Pin 1 (TN/WH) of the Blue ECM Connector if its a 2006 w/E40 ECM or Pin 53 (TN/WH) of the Gray ECM connector if its a 07-09 w/ E67 ECM.
If all of the above continuity checks test good, you may have a faulty TCM that is not passing serial data communication through to the ECM. I have seen this happen before. To test that you need to bypass the TCM. To bypass the TCM, unplug the TCM connector, get a couple of paper clips or some small wires, and make a jumper between TCM connector Pin 6 (L-BU) and Pin 37 (TN) and then another jumper between TCM connector Pin 7 (D-BU) and 38 (TN/WH). This will connect the 2 High Speed GMLAN wires at the OBD2 port directly to the ECM, bypassing the TCM, which should then allow you to connect to the ECM. If you are able to successfully connect to the ECM after making the jumpers, then you need to replace your TCM.
06 TBSS E40 Blue Connector
07-09 TBSS E67 Gray Connector
TCM Connector
OBD2 Connector
Old Aug 4, 2014 | 08:27 AM
fillpot's Avatar
Brother I greatly appreciate that info, I've got a buddy that's a GM tech that's going to help me with it this afternoon, I'll post back up tonight. THANKS
Old Aug 4, 2014 | 11:45 PM
fillpot's Avatar
Guy's finally got the dam thing thanks to branndown, it was the tmc, never would have dreamed it. THANKS!
Old Aug 4, 2014 | 11:49 PM
V8Rumble's Avatar
Good deal.
Old Jun 3, 2017 | 07:55 PM
Liwa62222's Avatar
TCM Connector
OBD2 Connector
The is great info. I have lsa engine and 6l90 transmission with or harness form źl1 comaro it has e67 ecm I have difficulty to wire the obd and throttle pdell to the ecm can you help me in this regards
Liwa62222's Avatar
