LS3 64 IMPALA almost done
Radiator.
I see you used a cross over tube to connect the upper water hose to the left side of a regular SB/BB style radiator.
Does that work OK?
I'm putting a 480 HP LS3 in my 61 Impala and already have a nice (and Expensive) Aftermarket Aluminum Radiator with the standard right lower/left upper connections and I would like to keep it if it will Cool OK with a set up like yours.
Thanks,Darrell
Does that work OK?
Thanks,Darrell
WOW. Badass ride. What seats are those? Pretty trick interior.
Thanks. How comfy are the seats? Do they recline? What model are they? Elite?
The seats are I believe the rally low back by Scat/Procar. They are comfortable but on the firm side. They are still not upholstered so they should be just right when done. They also tilt and slide so good range if that’s needed.
