Need a little help with Wiring harness
Old Aug 13, 2014 | 09:54 PM
DTFB's Avatar
Default Need a little help with Wiring harness
I'm using a 98 LS1 F-body wiring harness for my LQ swap into my 94 Formula (owned it for 7yrs) and got the LQ9 for a steal.
On Connector C100 I'm missing or can't find wires D (Traction Control Active), G ( Power Feed to Ignition Fuse #11), and k (power feed from injector fuse #10)
On Connector C210 I'm missing or can't find wires
B (Ground feed to fuel pump relay)
C (Power Feed From PCM BAT fuse to PCM)
D (feed from fuel pump and fuel pump relay to prime connector)
On Connector C220 I'm missing or can't find wires
D (Spark Retard request)
E (Throttle Position Sensor signal (EBTCM))
F (Serial data signal)
J (Fuel Pump Relay)
On Connector C230 I'm missing or can't find wires
C (Diagnostic request signal)
G (Power feed from PCM ignition fuse #5)
K (Automatic Torque converter clutch control)
I'd send it to SparTech if I had the money and time. But had to pay part of fall semester classes out of pocket and start school next week.
Your help would be greatly appreciated.
