'65 C10 SWB Build
Just wanted to see what it would look like with the new 29" wheel/tire setup.
This is as low as it will go with the factory trailing arms and no c notch.
Planning on running the PB stage 2 deluxe rear, so I'm sure it will do down another few inches.
also, the motor is pretty much ready to go in.
CPP Disc brake setup
ECE LS motor mounts - these things are heavy duty.
Anyway, both sides of the cab look like this at the moment. About to start installing nearly $500 in patch panels (super inexpensive compared to many classic cars).
So are you putting the C60 grill in it? Does it fit without many mods? Got any pics?
