2007 LQ4 Intake Swap Question
Some information: The engine has DT mid headers and eventually I will be swapping to L92 heads and a cam. Way later (years) down the road I would like to add some forced air (prob a single turbo).
Q1) What intake options do I have? I see most people are using an LS6 intake? Does it matter the year because I see several ebay ads stating to check the year to ensure proper fitment.
Q2) What size TB do I need to run?
Q3) Will the stock injectors be plenty for now until I change heads/cam later?
Q4) The current computer/TB are DBW. If I switch the intake to cable, can a tuner correct this in the ECM or do I need a new one? Or will my current TB bolt up?
Sorry for all the repetitive questions that have prob been asked 10000000 times. I feel like I spend 3+ hours every night reading and searching for info and when I go to bed I'm even more confused than when I started. I'm lost as soon as the carburetor comes off....
Info here.
http://www.lt1swap.com/cable_conversion.htm
Use a truck dbc throttle body. It will interfere with truck water pump and idler pulley on truck alt/p/s bracket. Some have cut cruise bracket off of throttle body and squeezed together throttle cam with success, but most change out water pump to LS1 style. Truck alt bracket will require mod and idler relocation bracket or change to aftermarket corvette style.
Engine harness will require to pin in for tps and iac (7 wires total) and pcm will require flashed to dbc.
Info here.
When you say they should work "OK" you don't sound like you are encouraging me to run this combo. LOL Like I said, I'm new to the LS based engines and sorta lost. If that isn't what I need, please be blunt and tell me. I'd hate to purchase something and regret it later. Do I just need an LS1 intake? I will be doing cam/heads/tune in a few months. Also I searched online and didn't find a lot of info about aftermarket DBW TB's. Is the common thing to convert it to DBC? I was going to try and keep the DBW because I read it was better for throttle response if tuned properly and required little to no maintenance as the cable did. Also the DBW has the cruise control built in and I was hoping to keep that as a feature for the truck.
I'm so lost....
YEs, PCM will say blue on one connector and green on other.
By "OK" I mean you may be close to 100% duty cycle on the injectors. Adding a bigger cam, headers, and better heads usually will require bigger injectors. You should be able to tune it with a stock engine and headers though and run well.
I believe you can bolt on the LS3 intake to your combo and run it. The port mismatch will most likely not be noticed on a stock engine. Add the bigger cam to it without changing heads to match will give you a tuning issue.
Just looking for a strong running truck that has a nice thump and is a reliable driver.
Attachment 724592
https://ls1tech.com/forums/generatio...video-how.html
https://ls1tech.com/forums/conversio...k-intakes.html
