NASTY64 Belair Project
Old Oct 13, 2014 | 01:25 PM
nasty64's Avatar
Default NASTY64 Belair Project
So here she is. Frame off restoration. Frame is completely painted, global west suspension, MB Old School wheels 18x8, 20x8.5. 5.3ls with a fully built th350, single s475 turbo on order, North Texas Converter 258mm mechanical diode converter on order, roller rockers on order, comp cams custom grind turbo cam, cpp 500 box, front drop spindles. More pics to come. She's going to paint the 28th of this month. Tripple black with peanut butter interior. Front bench seat is from a 61 pontiac bonneville.
Attached Thumbnails NASTY64 Belair Project-20140927_143906.jpg   NASTY64 Belair Project-20140926_155734.jpg   NASTY64 Belair Project-20140927_191943.jpg
Old Oct 13, 2014 | 01:27 PM
nasty64's Avatar
More pics
Attached Thumbnails NASTY64 Belair Project-20141013_131126.jpg   NASTY64 Belair Project-20141012_200109.jpg   NASTY64 Belair Project-20141013_131058.jpg
Old Oct 13, 2014 | 01:31 PM
nasty64's Avatar
Some more pics
Attached Thumbnails NASTY64 Belair Project-20141013_131219.jpg   NASTY64 Belair Project-20141013_131145.jpg   NASTY64 Belair Project-20141013_131252.jpg
Old Oct 13, 2014 | 05:48 PM
Renegade6's Avatar
It's nice to see more B bodies on here.
Old Oct 13, 2014 | 07:31 PM
nasty64's Avatar
Anyone running a stock ls1 radiator/fan setup on our b bodys?
Old Oct 14, 2014 | 08:48 PM
Renegade6's Avatar
That's what I plan on running on mine. Based on the measurements, it should fit nicely. I just need to come up with something to cover the top of it.
Old Oct 14, 2014 | 10:23 PM
nasty64's Avatar
Ok, perfect. I'll order mine tonight. Any particular year?
Old Oct 15, 2014 | 09:23 PM
Renegade6's Avatar
I still need to purchase mine and where you are with yours, you will probably put it in before I do. I was thinking along 2000 MY to buy.
Old Oct 16, 2014 | 01:19 AM
nasty64's Avatar
My turbo came in today!!
nasty64's Avatar
http://www.himni-racing.com/turbocha...rbo-t4-turbine
Old Oct 16, 2014 | 01:21 AM
nasty64's Avatar
My car is going to paint next week. So I'll be installing the motor/trans and turbo setup once the paint is done. Then I can measure for radiator fitment. Your thinking of a 2000 year ls1 radiator?
Old Oct 16, 2014 | 02:02 PM
Forcefed86's Avatar
Looks like a quality item!
In for results!
Old Oct 16, 2014 | 05:07 PM
nasty64's Avatar
In for results!
Thx I did not know it was not a standard run of the mill s475. Nice turbo, thx for the sale
Old Oct 17, 2014 | 05:57 PM
Renegade6's Avatar
Yes, a 2000 LS1 radiator. They should all be the same for those model years.
Old Oct 20, 2014 | 12:04 AM
nasty64's Avatar
Ordered the radiator and fans on ebay for 150. Came out of a 2000 camaro with 65k miles
Old Oct 20, 2014 | 07:11 PM
nasty64's Avatar
Anyone running a front mount turbo setup on our x frame cars? I bought an f body hotside kit that places the turbo in front of the motor. Im thinking all I'll need to dois recess the ls1 radiator to make it fit.... waiting on the hotside to mock up. Just curious if this has been done. Thx
Old Oct 21, 2014 | 02:25 PM
nasty64's Avatar
Did some test fitting last night. The motor fits great, just need to clearance the engine crossmember to clear the oil pan. The f body hot side does not fit in a x frame car. So I'll be flipping my exhaust manifolds and mounting the turbo on the right forward side of the engine bay.
Old Oct 21, 2014 | 02:28 PM
nasty64's Avatar
Here are a few pics. I'm using dirtydingo slide solid engine mounts and 2000 ls1 oil pan.
Attached Thumbnails NASTY64 Belair Project-20141021_031514.jpg   NASTY64 Belair Project-20141021_031459.jpg   NASTY64 Belair Project-20141021_031728_1.jpg
Old Oct 21, 2014 | 02:31 PM
nasty64's Avatar
More pics
Attached Thumbnails NASTY64 Belair Project-20141021_031642.jpg   NASTY64 Belair Project-20141021_031710.jpg
Old Oct 21, 2014 | 04:47 PM
nasty64's Avatar
Found a company called Roman Performance and Fabrication out of Illinois. They specialize in exhaust manifolds for turbo applications. 300-500 a set all custom made, magnifluxed, and with v-bands built into the manifold.
