New Gen V project...
Old Feb 15, 2019 | 12:27 PM
  #81
custom 68's Avatar
I am going to install mine in my Camaro to try it. It doesn't seem right to have a v6 in a Camaro but best I can tell and figure the power is good and the weight will certainly help. Should make for a fun driver. I wanted a shorter pan as well but for now am going with what I have. This may come out and a v8 go in but time will tell.
Keep us updated this is a fun project.
Dave
Old Aug 4, 2019 | 06:57 AM
  #82
96 Comp T/A's Avatar
So it may seem like this thread is lost to the ages, but bare with me. I am picking up the car that this is going in next week. I just rebuilt the transaxle, changing out 3rd and 4th gear ratios to something more appropriate and flipping the ring gear over to work in a mid engine application. The oil pan is about 95% done (I still have to trim the baffle to fit the shorter floor. I was intending to put an LT4 blower on the engine, by shortening the rear of the housing, but after dissecting the transmission, this transaxle isn't going to handle it, so I'm going to shelve that part of the project for a while.
Old Aug 29, 2019 | 08:45 AM
  #83
FogOfWar's Avatar
When trying to fit the LT4 blower, did you check the bank offset? I'm really curious did GM alter the bank offset due to split-pin crank or not. In Buick terms, off-center(rods not centered on pistons) or on-center. Maybe you have a picture from sump towards pistons?
Old Aug 29, 2019 | 10:14 AM
  #84
There was no change in bank offset on the Gen IV engines. It wasn't changed on the Buick V6 either when the crank was changed from common to split throw.
Old Aug 30, 2019 | 12:38 AM
  #85
FogOfWar's Avatar
I was referring to stage blocks(153 was altered bank offset to have on-center design).
If the LV3 design did not change the bank offset from L83 then it'll have to have the off-center rods.
Old Aug 30, 2019 | 10:50 AM
  #86
OK, you didn't make that distinction. Sorry.
Old Sep 1, 2019 | 04:47 AM
  #87
The bank offset is the same, the ports all line up. What does suck is that they added an extra inch to the front of the engine, so instead of saving 4.4 inches in length, it's really 3.4" shorter, so not really as much of an advantage as I would have hoped. I have not put it back on the stand, to re-attach the oil pan. I need to pick up a tube of yama-bond type glue or whatever sealant they use instead of gaskets in a Gen V.
Old Oct 25, 2019 | 07:46 AM
  #88
FogOfWar's Avatar
There was a question about weight.
I finally got mine from the US and with a very simple pallet (~10ft of 2x4) it was 460lbs. Whole engine with exhaust manifolds and wiring. Less alternator, starter and A/C compressor. Oil and half of coolant still in it.
Old Jan 20, 2020 | 03:03 AM
  #89
JDEK's Avatar
hey man i noticed your located in Tampa Florida, best place i can chat with you? via email facebook or even your number. would like some info on a cam. wondering if you knew anything. would like to cam my 2014 v6
Old Apr 11, 2020 | 01:38 AM
  #90
rays35's Avatar
[QUOTE=96 Comp T/A;19973967]So before I went and cut one of these on the mill, I had a friend 3d print one so I could check fitment. Pretty neat! I found a couple of dimensions that needed some minor alterations, so I made those changes. This will use the late LS3 style thermostat, not the LT style.
Just wanted to follow up to see if you ever finished this project, also, do you know anyone who makes these???
Old Apr 12, 2020 | 08:56 AM
  #91
Jimbo1367's Avatar
3d printing is pretty cool piece. Saves time and money. Ya got lucky a friend had access to one.
Old Apr 27, 2020 | 01:23 PM
  #92
rays35's Avatar
How can I make contact so I can get my hands on it
Old Jan 1, 2021 | 03:41 PM
  #93
MarkUnderwood's Avatar
How did removing the balancer make the motor idle and run?
