72 chevelle LS swap
Any issues with the AC bracket? I really want to put mine on and am going to look at cutting the clearance out like you have it.
Thanks about the tunnel, I looked online to see if anyone sold a tunnel and I decided I could probably just make one that fit exactly the way i wanted it.
As for the ac bracket I saw on here someone else thought of doing something similar. But everything clears nicely, I was on my phone so I was kind of vague on the details.
So the mount perches hung off the cross member from the factory. And the dirty dingo double d mounting plates were drilled for 4 positions stock bell housing, 11/16 forward, 1 11/16 forward and 2 1/4 forward of stock bell housing. So I needed the ac compressor to clear the mount not the adapter plate so I moved the perch back on the cross member back 1 11/16 then moved the mount on the adapter plate back to those holes. So its actually in stock bell housing position.
Other than that I haven't had any issues with clearance, I haven't spent the time to finish ac yet. I wanted to drive the car so I'll finish the ac over the winter.
Also, I kind of liked the look of the Centerline autodrags, I know they're dated but I always liked the set I used to have on my car.... Also I liked the center lines but they don't offer a 5.5 backspacing on a 15x10 so I can tuck the 295s. And I wanted something different other than the traditional 5 spoke. I'm going to buy some 18s one day if I find some I want.
Haven't had any issues or leaks yet.
