LS1 swapped 240sx S14 Issue
Old Oct 27, 2014 | 08:31 PM
GrifBall4's Avatar
Default LS1 swapped 240sx S14 Issue
Hey everyone,
I have a ls1 swapped 240sx and I can not get it started. I have power to the chassis and the starter turns the motor, but I have no fuel or spark. My fuel pump isn't even priming when the ignition is in ON position. I have checked power to everything, pump, coils, injectors, and PCM. They are all getting power but the car wont seem to start... Any idea what else I could check/do to maybe fix the problem?
The car was running for about 4 months with no issues. The other day on the way to work it sounded like it was starving for fuel. When I pressed the gas it didn't do anything and once the car came to a stop it died and just turns over now. Any help is much appreciated.
Old Oct 27, 2014 | 11:55 PM
Mercier's Avatar
VATS? When you say you checked power to pump, do you mean you had power there but still the pump doesn't run? That could be a ground issue. Did you maybe lose a ground from the chassis to the motor or similar? Have you connected a scan tool or better to see if the PCM is alive and responding?
Old Oct 29, 2014 | 09:39 AM
GrifBall4's Avatar
VATS should be disabled, should be... Yes, there is power to the pump but it still doesn't run/prime. i pulled the pump and put it straight to the battery and it worked just fine. I connected my friends Diagnostic scanned and it wasn't picking up the PCM. I want to consider the PCM a last resort because they can be quite pricey.
Old Oct 29, 2014 | 05:46 PM
Mercier's Avatar
If you have power to the PCM but no output to the OBD port, I would check continuity of the wires between PCM and port and then from ignition switch to PCM. If all that checks out, I think you have to look at PCM. Is the PCM properly grounded? Did you check OBD port with the key in the /on/ position?
I guess our budgets are all different but I've seen plenty of good used PCMs for $100-$150. Seems like a worthy investment considering if that is not the issue you can probably sell the extra back on the forums for about the same price.
Good luck.
Old Oct 30, 2014 | 03:17 PM
2muchboostNY's Avatar
OEM 411 PCM's can be had for about $75-150. You can contact LSXMalibu on here he usually has a few. Also, Wiring Specialties has some in stock usually and can sell you some.
Old Nov 1, 2014 | 02:51 AM
Mercier's Avatar
Old Nov 15, 2014 | 07:15 PM
GrifBall4's Avatar
Okay, so if I buy a 411 ecu how would I get it tuned to my swap? Because I don't know the VIN for the car it came from.
Old Nov 17, 2014 | 10:05 AM
A few ways to handle this. I sent mine to Wiring Specialties since they made my harness. They did the base tune removing everything I didnt need/want for my S14 swap and thats it.
http://www.wiringspecialties.com/hptuls1pcmst.html
