Smaller Power Steering Pulley
Old Nov 4, 2014 | 11:34 AM
gpr's Avatar
gpr
Default Smaller Power Steering Pulley
I need a smaller PS pulley for the truck power steering pump. Put a 5.3 with truck accessories into a 1971 chevelle. Like others the stock pulley is to large and hits on the power steering box.
I read many different threads and it looked like Dorman 300-201 was the only answer... But it is plastic and seemed like you needed to press it on the shaft much further. I ended up buying Dirty Dingo's smaller pulley. Turns out that is just a dorman 300-201 pulley that they chage $30 extra for….
I'm wondering if anyone has found a good solution, and preferrably a pulley that isn't plastic? I want to reuse the stock accessories since I have them already.
Old Nov 4, 2014 | 12:24 PM
1964SS's Avatar
I haven't tried it, but I've heard of people using a Monte Carlo v6 3.8l pulley. It is not as small as the 300201, but it is smaller then the truck pulley and it is steel. Might be worth looking into. Rock auto has it listed as a dorman 300130.
Old Nov 4, 2014 | 02:31 PM
LS1-450's Avatar
After you resolve the pulley issue, probably wise to add a PS cooler if there isn't one. That smaller pulley's gonna heat the fluid up quicker.
Old Nov 4, 2014 | 04:21 PM
garys 68's Avatar
I wouldn't worry about plastic unless you're turning 7000rpm.
Been running the 300-201 for years as a DD.
Look up the history of f body PS coolers before you add one of those.
Old Nov 4, 2014 | 04:25 PM
1989GTA's Avatar
When I did mine I also installed a 25% underdrive crankshaft pulley/dampner. This also slowed the P/S pump back down.
Old Nov 4, 2014 | 05:21 PM
gpr's Avatar
gpr
How do you get the pulley off? I had to press it on so far that a PS puller would no longer be able to reach and remove the pulley. Plus it still needed to go on further because it wasn't quit lined up yet... I think i have seen where some put washers on the front side of the pump to move it further back. I might try this.
I will probably try the 300-130 and see which fits better.
Old Nov 4, 2014 | 07:24 PM
ZQ8LS1's Avatar
I had the 300-201 pulley on my swap (S10 truck acc) & kept having issues with the pumps going out & contributed it to the smaller pulley & heard of a few guys that had the pulley come apart turning high rpm.
I went to this bracket & never looked back,works great & runs stock 5.3 pulley.
http://lsbrackets.com/category/ps-alternator-brackets/
Pics on page 3 of my swap,link in signature.
Old Nov 4, 2014 | 08:25 PM
76larkman's Avatar
Default steering pulley
I just put a 5.3 into my 76 skylark. same problem with pulley steering box clearance. I used dorman 300-130 for a 3.8 v-6. I had to put 2 washers at each of the mounting points between pump & bracket. pressed pulley on further then the belt lined up great. bracket on back will have to be modified. cut & shorten weld back together. hope this helps you out.
Old Nov 5, 2014 | 12:55 AM
garys 68's Avatar
Im cut some 0,200" aluminum spacers between the pump and bracket. That way the PS pulley could be used to reach it if needed.
Pic of install on my Olds threaf.
Old Nov 5, 2014 | 05:01 PM
jimmyg's Avatar
Guy on u tube used a 5 in pulley from o Reilly's 19$ he didn't give part #
Old Nov 10, 2014 | 10:18 AM
gpr's Avatar
gpr
Thought i would update this thread. I tried both the 300-201 and 300-130. the 130 pulley works much better. It is steal, so won't break, and fits on the truck PS pump better. The 130 pulley is slightly larger than the 201, but it still has plenty of clearance with the steering box. Because of the larger size it doesn't have issues with the bolts on the PS pump, as when using the 201 i have seen people have to use lower profile bolt heads.
Hope this helps people out in the future.
Old Dec 2, 2014 | 10:21 AM
samickguy15's Avatar
300-202 is the metal version of the 201. I just ordered one to try out on the swap my brother-in-law and I are working on.
Old Dec 11, 2014 | 08:22 PM
blyne3's Avatar
Sam did the 300-202 work?
Old Dec 11, 2014 | 08:42 PM
bczee's Avatar
A few years ago. Many were using the pulley from late 80's E-150 vans. Search and you'll see many threads.
BC
Old Dec 12, 2014 | 01:35 AM
66Chevellelq4's Avatar
i pulld one from an e 150 ford van. I compared it to the stock pulley and it looks like its gonna work. I will have results in about a week!
Old May 23, 2017 | 01:48 AM
LSX REX86's Avatar
Default Do you have any pics m
to make sure I'm following u right u used to washers between the pulley and took to help push the pulley back some
Old May 24, 2017 | 08:19 AM
garys 68's Avatar
The different contour of the pulley can contact the pump snout before it lines up correctly with the pump in the original location.
I use 0.2" aluminum spacers between the pump and bracket. You can barely see one in the upper bolt in the pic below.
I also replace the taller hex head bolts with lower profile button head to clear the pulley.
Old May 24, 2017 | 10:16 AM
JoeNova's Avatar
Restricted User
I do something similar. I have a .2" washer that just fits over the pump shaft, and I use it while pressing on the pulley to seat it .2" beyond that end of the pump shaft. Works every time.
