Relay holder, where to find?
Old Nov 9, 2014 | 01:02 PM
Bowtiedford's Avatar
Default Relay holder, where to find?
I'm looking for a holder like a factory setup to hold about 4 to 5 relays. I can't seem to find anything, maybe I'm using the wrong wording? Something new or maybe something out of the junkyard? I am close to a local LKQ yard. Any help appreciated.
Old Nov 9, 2014 | 02:20 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Is this something like what you are looking for? It will control engine, trans, Fans, and A/C!
http://www.ebay.com/itm/LTX-LSX-Vort...e=STRK:MESE:IT
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Nov 9, 2014 | 03:00 PM
Something like that it's for my 4 nitrous solenoids and standalone pump and maybe 2 other things. It's all wired just relays are just hanging there. Looking to make it cleaner. A/C and fans I already have it done. Thanks.
Old Nov 9, 2014 | 05:51 PM
LS1Tech Sponsor
we can fit 6 relays and 12 fuses in that setup.
We can also custom build it for you, but to do so we would need you to send us a diagram and there would be about a 5-10 business day lead time on the order.
Price would be in the same general area as that item.
Bill
__________________
1-888-467-4491
Old Nov 9, 2014 | 08:05 PM
lizeec's Avatar
Here's a thread with some good ideas.
https://ls1tech.com/forums/conversio...e-harness.html
Old Nov 9, 2014 | 09:22 PM
Thanks gives some ideas. I guess I'll go to the junkyard and just check around and see.
Old Nov 9, 2014 | 09:33 PM
garys 68's Avatar
I honestly wish I found the BP years ago when I was doing mine.
What I used, but had to piece together fuse/relay panels:
http://www.haywireinc.com/index.cfm/...rod/prd167.htm
Old Nov 11, 2014 | 01:08 PM
Houston_t's Avatar
http://www.ebay.com/itm/4-Way-Splash...ht_4449wt_1238
If you want something factory ford uses then in a lot of their vehicles. Check out like an 01 taurus/ sable or other years that body style, should be one underneath the battery box.
Old Nov 11, 2014 | 03:49 PM
DW SD's Avatar
I bought this relay box... just over $100 and it is super nicely done. It is small and uses mini relays.
http://www.wranglerforum.com/f202/wi...ox-547057.html
The builder can make it ground - triggered or 12V+ triggered, etc.
Doug
Old Nov 14, 2014 | 01:18 PM
Ernie W's Avatar
Bill
Bill, I've tried to call a few times and you must be a busy man. I've got a few questions about the relay box. I'm building a '80 Firebird with a 6.0 6 speed. I see you sell the bussman sealed box, could a person get that fuse box set up for the DBW LQ4? Price on it?
Old Nov 14, 2014 | 03:00 PM
chuckd71's Avatar
Fairly recent Jettas and Passats have pretty decent computer boxes on the driver's side near the windshield. Kind of hard to get out, but might be worth a look.
Old Nov 14, 2014 | 07:38 PM
Pocket's Avatar
Fbodys and late 90's cadillacs use the modular fusebox BP sells
Surf mouser.com for the delphi stuff, the fuseblock section is massive
Old Nov 15, 2014 | 06:08 AM
Anubis403's Avatar
Blazers and Jimmy have nice relay set ups on the firewall. IIRC, each one has 3 Bosch relays on them. If you need 6, you could mount 2 side by side. Mounted in another vehicle they look factory stock and LKQ will have them.
Old Nov 15, 2014 | 07:29 AM
Thanks for the info guys, I went to lkq and found one out of a Lincoln, holds six relays and compact enough for me.
Holds: stand alone fuel pump (for nitrous) 1
Nitrous 2 (have 4 solenoids)
Fans 2
I have one relay in engine compartment just hanging (unknown)
Total six, perfect.
Old Nov 15, 2014 | 07:03 PM
Pocket's Avatar
If you just want relay strips, check out GM mid 90's mini-vans. Several have 5-7 relay strips in both the older oval style and bosch square style. They come with tin strips to mount them anywhere
Old Nov 16, 2014 | 02:51 AM
LS1MCSS's Avatar
It would be good to find one a little closer. That one is in the UK.
Old Nov 16, 2014 | 09:00 AM
TipsyMcStagger's Avatar
Here ya go Here ya go
Tipsy
