Couple quick questions
Old Nov 13, 2014 | 02:31 PM
Taxman20's Avatar
Default Couple quick questions
OK, I am new to the LS engines and am an old school guy when it comes to engines. I tried to find the answers on the forums here but didn't really see any hard answers on this. So thanks in advance for the advice.
I am going to install a cast iron blocked LS 6.0 and 4L80 trany out of an early 2000 model 3/4 to 1 ton truck. It will go into a 97 S10.
I am going to run a carb and the MSD box for the coils. I want to get the truck running pretty quick so I don't want to build a race motor just yet. I will buy the parts I need over a little time due to budget restraints right now for a good build later.
This is going to be a drag truck. Might drive it on the street but its not a daily driver. So radical is good. This is to play with while I gather what I need for the real build.
I want to know what the best cam I can get for the most HP with the stock valve train. I will change the valve springs if needed and probably the converter. I just don't want to replace, valves, rockers, do head work ect right now. Also what size carb is recommended. So all I want to do on day one is install a good cam, intake and carb, headers and let it rip.
The final plan is to build a full race motor for the strip. But that's later on.
Thanks for the info.
Old Nov 13, 2014 | 03:31 PM
svede1212's Avatar
Springs, retainers, locks, seats, seals and push rods are a must with any respectable cam. Timing chain and oil pump too. How high do you want to rev? Where do you want the power band? What RPM stall? The thing is to assemble that list and talk to a cam grinder. There are several good ones. Intended use and symphony of other parts will determine which one is best and not an internet poll IMHO.
Old Nov 14, 2014 | 06:49 AM
Taxman20's Avatar
Yea, all I am wanting right now is a good cam swap for a little more power. Since I am going to an intake and carb setup I figured I would also swap the cam for something a little more aggressive than the stock cam. This first engine is going to be a pull out with no rebuild. Just something to get the truck going and play with while I gather the parts for the real build. I'll also run the stock 4l80 trany for right now. Probably wont buy a converter for it since I will spend well over a grand for the race converter.
If I do all of the extra work for a true race build then I would do all of that research.
Again, I'm not new to engines. I build 1000+ HP big blocks before we spray it. The last strip car I had was an IHRA Top Dragster that ran mid 7's at 180 mph on motor with a Reher Morrison 565. But that's an older type chevy. I don't know a lot about the newer style blocks and heads and that's why I will do more research before I build a full race engine. I expect for the full race motor I will shoot for about 600+ hp from it then spray it another 150-300. Stall will depend on where this engines power band is best for max torque at launch and then use the HP for the big end. Our local track went to 1/8th mile and that's when I sold my dragster. I didn't build it to run short track. Wasn't very fun. But a small tire S10 might just be a little fun.
I do appreciate the advise if someone has done this before. Otherwise I'll just ask Comp and a few other cam companies which cam they recommend for a stock longblock.
Old Nov 14, 2014 | 07:31 PM
Taxman20's Avatar
Looks like no one has a clue on this I guess. I'll be calling the cam companies and checking with my buddy that builds drag cars and see what they say.
Old Nov 15, 2014 | 09:17 AM
farmington's Avatar
If it was mine.... I'd buy the best converter I could now (SS4000) and leave the motor stock. Best bang for the buck and it will still work with your race parts down the line.
Old Nov 15, 2014 | 10:31 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Taxman, welcome to LS1tech!
You'll get better answers here in the conversions section.
Old Nov 16, 2014 | 06:34 AM
garys 68's Avatar
Might interest you.
http://www.hotrod.com/cars/project-v...4-short-block/
Old Nov 21, 2014 | 03:02 PM
Taxman20's Avatar
Ok, Thanks for the help. I wasn't trying to be a smart *** but I own 2 businesses and have to, and am used to doing things fast. LOL So if I ask something I am used to getting direct answers pretty quick. If not I find a different route for my answers or needs.
Again, Thanks. I'm headed to that topic now.
Old Nov 21, 2014 | 11:25 PM
garys 68's Avatar
You'll get a lot more relevant responses with a title like "Cam for 500hp carbed 6.0".
90% of the people who can help you never even read threads with titles like yours.
