Alternator help
Old Jan 4, 2015 | 02:12 AM
NCFChad's Avatar
Default Alternator help
I have a 94 s10 with a lq9 swap. I swapped all the accessories over to c5 corvette. The c5 corvette uses a valeo alternator that runs through the pcm when using a factory harness. I am running the holley hp and I am not using a factory harness so I planned to convert the valeo style alternator over to a 1 wire. From what I just learned they don't make a 1 wire regulator for the valeo alternator.. any suggestions please? Thanks in advance!
Old Jan 4, 2015 | 08:50 AM
garys 68's Avatar
Search here for carbed LS swaps. No ecu and alternator is set up like a 1 wire.
Old Jan 4, 2015 | 03:20 PM
1981TA's Avatar
Maybe look for a pic I posted of my alternator wiring setup. I'd do it, bur my phone isn't playing nice today.
Old Jan 4, 2015 | 03:50 PM
Project GatTagO's Avatar
All you need is a switched power source to the second pin as viewing the alternator from the rear. The line needs to be run through the dummy light circuit in the dash or have a resistor installed. Google around for the exact value.
Andrew
Old Jan 5, 2015 | 12:01 AM
NCFChad's Avatar
Thank you.
Old Jan 5, 2015 | 05:15 PM
1981TA's Avatar
Here:
Old Jan 5, 2015 | 05:39 PM
I'm confused. Does "only when key is turned" mean only when cranking or on when the ignition is on?
Andrew
Old Jan 5, 2015 | 07:57 PM
EFIHARNESS's Avatar
On with ignition. All modern systems have ignition on while cranking. Any value
from Approx 100-470 ohm will work. Wire on alt stud ( blue arrow above) should be#8 or larger as Alt can output 100+ amps.
Use pin B in the 4 cavity connector . ( Green arrow above, also it is metri-pack 150, not weatherpack ). Steve
Old Jan 5, 2015 | 11:23 PM
1981TA's Avatar
yup, what EFI said
Old Jan 19, 2015 | 11:24 PM
NCFChad's Avatar
Originally Posted by 1981TA
Here:
Thanks sooooo much! Its much easier when its right infront of me!!! Thanks again!
