Good, inexpensive car for LS swap?
Also, will the Hooker set up provide the clearance needed for a 4" stroke LS engine.
The price of the Hooker parts are $950-1500 depending on the headers you get but considering most "budget" g body swaps use painted Pacesetters it only seems fair to use the price of Hookers painted 1 3/4 LT's when comparing priced. Ebay adapter plates $25, Summit transmission crossmember $275, and painted Pacesetters $300 and up to $600. So like I said the Hooker parts are only $350 more.
If you want to run a 4 inch stroke crank the cheapest easiest way would be to notch the back of the crossmember and use a f body oil pan, plus then you save $150 over Holleys pan and even more if you get the pan used.
Quote from Gbodyforum.com
"Using 1" set back mounts like Dirty Dingo and those available on Ebay, stock truck accessories will clear a g-body hood if you use the 105 amp alternator. Some of the power steering pump pulleys will not clear the g-body steering box. You can swap the pulley out for a smaller one. Pulleys are available at your local parts store under the doorman brand name. F-body accessories will also work, and give more hood clearance, but are hard to find in the yards. When you do find a set, they usually want quite a bit for them."
See link below
https://gbodyforum.com/viewtopic.php...6#.VLsNXE1OUUR
As everyone knows, the 200R4 was the performance transmission for G bodies from the factory. All GN, T types, MCSS, Hurst Olds and 442 G bodies had them. When using 1" set back engine mounts it is possible to retain the factory transmission position without driveline or hood clearance issues. As I noted before, I'm not excited about the fact that the Hooker system requires that I move the trans forward by 1/4" which messes up the transmission linkage and requires a new driveshaft ($200 or more). For guys going with a newer transmission, the hooker set up is the way to go.
To say that an LS engine was able to be bolted into the chassis of a car and the car was then driven down the road under the power of that LS engine in itself does not indicate to me that the swap was successful.
I would deem that same car to be an unsuccessful swap if upon inspection I found it to exhibit any of the following characteristics:
Non-optimized U-joint working angles
Hammered or cut trans tunnel sheet metal to clear the transmission
Hammered or cut underside of hood to clear engine components
Clearanced or removed A/C evaporator case (it's a personal thing)
Poor header collector ground clearance
Headers used from another application with tubes hammered for clearance
Large chunks of the 4L80 case being hacked off to clear long-tube headers
Undersized stock driveshaft being utilized where stronger shaft is needed.
All of these characteristics (and more) were observed in build threads that I researched before I began the design of the Hooker parts and they heavily influenced my design efforts and the amount of time spent mocking up the engine and transmission in the car before any component design work took place.
I respect your right to hold a different opinion as to what constitutes a "successful" swap.
See link below
I have spent a lot of time making my non standard (IE not AJE) fox swap work from the system level perspective, and frankly, if I could spend some extra money from a vendor and get what I want from the system level, then it is worth the extra money. IE, if someone made a road race variant Fox Mustang LS swap kit, it would have been worth buying. Unfortunately, nobody does.
Such as 240sx, miata, rx-7, bmw 3 series e30 or e36.
You can find all these cars for pretty cheap and their are many companies that make swap kits for these cars.
Late 80's cougar and thunderbird are definately cheap and share a huge amount of parts with fox body mustangs.
I can't personally do a G-body, a lot of them became dirt track cars, and they guys racing them all seemed to throw one together all ratty for the street. Sorry G-body guys thats just how see them
I did a frame off on my 86 Monte Carlo ss and I had no problems finding/ordering brand new interior/exterior parts for it. They are getting harder to find in nice shape though, and the prices of solid cars foes seem to be going up. Up in the rust belt. $3k usually doesn't get you much.
And I'm partial to the square bodies. EASIEST swap period
