need help!!
Old Jan 19, 2015 | 06:21 PM
vissiajs's Avatar
Default need help!!
So a supposed shop that does ls swaps did my swap. I have an lq9 being ran by a fast ez efi\ fast xim. In a 92 Silverado, the only guages they could get to work was fuel and battery. They completely cut out the factory harness. From what I can find I'm going to have to get Dakota digital mgi-5/8 to run my tack and speedo. Am I able to wire the therm. And oil pressure direct?
Old Jan 19, 2015 | 06:52 PM
redline2k's Avatar
You should be able to wire a temp sensor and oil pressure back to the dash. I would not try to piggy back with any sensors that the FAST uses. That can lead to inaccurate readings.
Old Jan 19, 2015 | 07:02 PM
vissiajs's Avatar
Default ok
I wasn't sure if they went to ecm first like the speedo and tach does.
Old Jan 19, 2015 | 09:36 PM
redline2k's Avatar
The ecu has an engine coolant temp sensor, but no oil pressure sensor. You just need to add the 2 sensors and wire to dash. The temp wire on the dash should be green, and the oil pressure should be tan.
Old Jan 20, 2015 | 07:19 PM
vissiajs's Avatar
Default thank you
Thank you very much.
