240sx LS>VQ build thread.
Old Feb 10, 2015 | 05:42 AM
laurentj23's Avatar
No update from the shop yet. I dont think he started working on my car yet. But in contemplanting on selling the engine and get ls3. Someone please tell me why i shld or shldnt do it! Lol
Old Feb 10, 2015 | 12:09 PM
Nissan LS240's Avatar
ls3 is going to require a different harness and ecu and a gas pedal, but you do get a better motor, I'm happy with my 383 Ls1, but I'm in the process of building a Lq4, yes its an iron block but its way cheaper than the ls3 and can take just as much boost
Old Feb 10, 2015 | 03:11 PM
2muchboostNY's Avatar
Really depends on your goal. If you want a max effort NA then an LS3 is a great option but expensive and as noted requires different swap parts. If you want something a little cheaper but yet still capable look at the L92 (6.2L) or an LQ9 (6.0).
If you are planning on going turbo then I would say a 4.8, 5.3, LQ4 or LQ9 is the best bang for the buck. 4.8's can be found for $300-400.
Old Feb 10, 2015 | 04:45 PM
laurentj23's Avatar
I was looking at the body swap ls3, and it doesn't states anything about needing new PCm. I thought the 411 is programmable and all I need is adapter for the cam sensors with lingenfelter converter, knock sensors extensions. Im also going to convert it to cable instead of Drive by.
Old Feb 11, 2015 | 11:31 AM
you can do that too, I'm not sure on the ecu though I always thought if you had a 24x ecu you had to use a 24x crank, I've heard of people replacing the reluctor ring to make it work, but not sure if there's a converter box for that, but I haven't really looked for that
Old Feb 12, 2015 | 05:38 AM
laurentj23's Avatar
Iingenfilter makes a convertor box for that but it cost arnd 300 bucks. I m not sure which one is cheaper. Changing the reluctor wheel or getting the box.
Old Feb 12, 2015 | 09:39 AM
all depends if there's a local shop that can do it for you, but changing the reluctor wheel I think would be the cheapest, but not when you have to spend money on shipping or gas
Old Feb 20, 2015 | 06:14 PM
laurentj23's Avatar
Ok i just got an update from the shop. The mechanic said that my timing is off. I did make sure that my crank and cam dot aligned when i installed the cam.
Will an inaccurate timing cause it to not start?
Old Feb 23, 2015 | 03:59 PM
HectorM52's Avatar
Absolutely. Got any pics of your dots lined up correctly?
Old Feb 24, 2015 | 02:47 PM
hopefully if it is out of time, it didn't bend some valves, and just to be sure you aligned the outer dots towards each other, as in the cam dot facing down and crank dot facing up? and you did use the outer dot on the cam gear and not the dowel pin? I know these are stupid questions but I've seen some even more stupid mistakes, sometimes by me
Old Feb 25, 2015 | 10:22 AM
laurentj23's Avatar
Unfortunately I don't have the pics to show you guys. Im pretty sure I had it done right, but who knows. Now the mechanic has to tear everything apart again and hopefully fix the issues. I shld have use the cam degree kit prior to installing everything.
Old Feb 26, 2015 | 08:05 AM
  #32
chuckd71's Avatar
Hey, what's up, I'm the guy in Atlanta selling/trading the 24X 6.2. Is your motor currently in the car?
If you have or can rent a leak down or compression gauge you can determine if you bent some valves, but you'd also hear backfiring if it were trying to start. I had some bent valves, but with the right tools that's a pretty easy thing to fix. Did you put the heads on with GM TTY bolts or reusable ARPs? If the latter then you're only out the cost of a head gasket and an hour to pop a head off and take a look.
If it isn't too tight in the engine bay, popping the front cover off to see if the dots are lined up isn't a huge ordeal in and of itself, and if they are off it's pretty blatant.
What is the noise at the 26-second mark in the second video? If it is the cam/crank randomly ending up in sync and sparking while a valve is open that's probably not the best sign. Random "puff" of pop noises coming out the front of the motor aren't reassuring. If it is just a random noise from you moving then disregard. Just my experience, I'm sure someone else will chime in.
Anyway, as far as trading motors goes, I think getting your motor to run in my car would be fairly simple if time consuming, but getting my motor to run in your car would be more difficult, since so far we don't know if the platform itself is even viable.
Where are you in GA and which shop are you at? There is a pretty well-regarded shop near Lawrenceville, I think the guy posts here as Trojan or something like that.
Old Feb 26, 2015 | 03:30 PM
  #33
laurentj23's Avatar
Chuck,
The motor is currently in the car. Its at my mechanic shop in jonesboro. He builds race car on the side and works at the nissan dealership as his main job so, im sure he will take care of the issues. And hopefully not a bent valves.
When i tried to crank if before, inhad plenty of backfires. Does that mean i bent some valves? I heard it mostly a thump sounds mostly on the header but it doesnt happen all the time. I havent had the chance to get a compression test prior to towing it to the shop.
Im using brian tooley head bolts so im guessing its tty bolts.
The ls3 motor will fit in the car. Just need to have extension for the wiring harness ect ect.
Old Feb 26, 2015 | 04:49 PM
  #34
chuckd71's Avatar
Any ls motor will fit, I had an ls1 where my 6.2 is now, both running the same computer, so the wiring and that is not an issue on my end. What I meant was that at this point it can't be determined with any certainty where you problems are originating. If there is a problem with your current car wiring then no motor is going to run there; if the problem is mechanical then mine would work no problem. A bit of detective work remains to be done.
I don't think the backfires have to mean valves are bent, but it would likely (someone correct me if I'm wrong) at least mean that it is sparking while a valve is open. Cam and crank might not be syncing, and I'd guess - guess - that either the cam is misaligned, a sensor is bad/miswired or you have the wrong cam gear.
No idea what your mechanic will do but if it were in my garage this is what I'd do (from easiest to hardest) -
Noid light/ spark checker (just because it's literally the easiest thing in the world)
See if the guy tuning it can show you what the cam/ crank sensors are seeing.
Compression/ leak down test. If nothing else pull a plug and stick your finger on the hole while someone turns it over.
Pop off front cover.
Pull a head.
Pull motor/ start from scratch.
Put known good motor in car and see if it runs.
Old Feb 26, 2015 | 09:37 PM
  #35
laurentj23's Avatar
Pull a head.
Thanks for the advise.
My mechanic kinda keep me in the dark on what he's going to do. But, I told him that Ill get the car if it's not fixed by the end of the month. I towed the car end of Jan and from there, Im gonna troubleshoot according to your suggestion.
Old Feb 27, 2015 | 11:20 PM
  #36
ls13ater's Avatar
Tow that bitch up here and I will get you right! I hate slow *** people, or mechanic that claim this or that, then get in there And figure out they put there foot in there mouth and can't find the problem so the avoid you.
Old Feb 28, 2015 | 08:22 AM
  #37
laurentj23's Avatar
Don't tempt me sammy! LOL. I might get a u-haul and drag my car down there!
Old Mar 13, 2015 | 09:25 AM
  #38
laurentj23's Avatar
Current update:
Alpha auto works pick the car up using their trailer and take it to their shop.$125. Apparently the first mechanic didn't even do any kind of work. Car has been on the same spot since I dropped it off in the middle on jan. So, now the car is at another shop. I'm hoping they will get it run sometime this week or next.
Old Mar 18, 2015 | 04:36 PM
  #39
laurentj23's Avatar
Engine finally running but it still backfire intermittently. The mechanic did a compression test and some cylinders are 15% off. It's a cold compression test though. And the car is running with open header which might cause the backfiring issue. Stand by for video tomorrow. Turned out the CPS was broken. So replaced that and it crank right up.
Old Mar 21, 2015 | 09:13 AM
  #40
chuckd71's Avatar
15% isn't that bad is it? I mean as long as it's 15% of a decent number and not 15% of 10 or something like that?
Either way, at least it's running now.
