240sx LS>VQ build thread.
try to start up today. it threw a code for cam sensor.
Mechanic said it looks like a bad lifters. The only thing i did to the lifters are changing one of the tray to ls2 tray.
any ideas guys?I told my mechanic to stop investigating since I'm upgrading to ls3. No point in keep dumping more labor fees into this.
How does a cam sensor code equate to bad lifter? I'm asking because that could be good to know. Even replacing bolts and gaskets, it would've been faster and cheaper to pull the heads or at least front cover. A new shop might be worth considering.
So he replaced the coolant temp sensor
let it run for a few mins and it literally fire started on the rear passenger header near the spark plug.
He said the engine doesn't sound healthy. It might be tuning, bad lifters or the lifter have not soak enough oil since the engine hasn't been run.
All in all, it gonna cost a lot more money to figure it out the issues, and I don't want to do that because ill be selling the engine and upgrade to ls3 in a few weeks.
compressions are arnd 210-190 across the cylinders
This is also with open headers
but how much does it cost to get that fix? any idea?
Don't know why I can't upload the video on here with photo bucket.
I saw some on sale here for 950 for just the short block. that is after i purchased this engine. I shld have when that route and get a whole different rotating assemblies and make it a 416 ci.
Looks like you're on the right track now though.
