240sx LS>VQ build thread.
Old Jul 24, 2015 | 06:10 PM
  #81
laurentj23's Avatar
Ready to be dropped in
L92 Block
Cleavite H Main bearings
Cleavite H Rod bearings
New Durabond cam bearings.
New Forged Mahle pistons and rings. slightly over
Fresh hone and bore.
Balanced rotating assemblies with 24x reluctor wheel swap.
Tick Street Heat stage 2
Iwis timing chain
Morel 5290 lifters
LS 9 headgaskets
Port and polish ls3 heads by Greg goods
Pac springs and retainers
stainless steel oversize exhaust valves.
Old Aug 1, 2015 | 09:03 PM
  #82
laurentj23's Avatar
Ceramic coating the x pipe and exhaust manifold
Old Aug 1, 2015 | 09:22 PM
  #83
Nismo Kid's Avatar
How's the quality on that 2 piece timing cover? Is that the Hawks unit?
Old Aug 2, 2015 | 12:21 PM
  #84
Jimbo1367's Avatar
Any pics showing off Greg Goods handywork?
Old Aug 2, 2015 | 04:49 PM
  #85
laurentj23's Avatar
I tried to ask the previous owner for flow #s data and pics but he delete it. douche..LOL
Old Aug 2, 2015 | 04:50 PM
  #86
laurentj23's Avatar
It's not hawk. I bought it off ebay..so far so good. Speedmaster sells one on jets for cheaper.
Old Aug 2, 2015 | 08:53 PM
  #87
Nismo Kid's Avatar
That's good to hear. Thanks for the response laurentj23.
Old Aug 26, 2015 | 03:56 PM
  #88
laurentj23's Avatar
Engine is in. Hopefully I will hear her run by next week!!
Old Aug 26, 2015 | 06:20 PM
  #89
ls13ater's Avatar
Finally!
Old Sep 4, 2015 | 06:07 PM
  #90
laurentj23's Avatar
Getting close! Should be up and running soon. Need opinions for tuning.
I had it ref lashed by vengeance for the ls1 setup so I need to get it retune. Should I do dynotune which there is none available till after ls fest and cost the cheapest is lamar walden 400 bucks. Or should I do the PAT g option of getting the EFI life Auto cal and buy their custom tuning and than dyno the car. This option is 625.
Suggestions?
Old Sep 5, 2015 | 06:06 PM
  #91
laurentj23's Avatar
Custom bracket for map sensor
You can't use ls3 map sensor if you're using ls1 pcm.
Old Sep 12, 2015 | 11:36 AM
  #92
chuckd71's Avatar
Karmaperformance in Nashville has a dyno, not a pit dyno but it's still a dyno I guess. I think Vetteworks or something like that has a pit dyno. Tennespeed forums (if they are still around) would likely have info.
Old Sep 20, 2015 | 03:19 PM
  #93
laurentj23's Avatar
Awesome thanks man. they start off at 200 per hr for tuning.
Old Sep 30, 2015 | 12:53 PM
  #94
laurentj23's Avatar
Exhaust setup. x pipe 3" with jones racing series resonator and exit on the side.
Hopefully I will get it back tonight!
Old Oct 5, 2015 | 03:24 PM
  #95
laurentj23's Avatar
Racepak gauge is in this weekend!
Old Oct 20, 2015 | 11:36 AM
  #96
laurentj23's Avatar
So after all these work, im back to square one! Wtf! Engine is showing the same symptoms as my old ls1. Paid my mechanic in 2500 total labor and the car still isnt running!
Pcm flashed with vengeance. It cranks when trying it at another car.
Reluctor wheel swapped to 24x. Cam gear is 1x .
Cam sensor extension harness has been switched and double check.
Crank sensor is black color.
Injectors are 42lbs stock ls3.
Im at lost guys! Im in the verge of parting this whole thing out!
Any help?
Cam is aligned right.
Old Nov 7, 2015 | 03:42 PM
  #97
2muchboostNY's Avatar
Did you get it figured out bud? Hate to hear all of the headache you have gone thru.
Old Nov 11, 2015 | 07:12 PM
  #98
ls13ater's Avatar
You ever get it right?
Old Mar 17, 2016 | 10:33 PM
  #99
ls13ater's Avatar
Any updates?
Old Mar 21, 2016 | 08:50 AM
  #100
laurentj23's Avatar
Originally Posted by ls13ater
Any updates?
Due bad luck after bad luck. So apparently the freshly rebuild ls 3 wont crank. Replaced the reluctor whee and still wont crank. Check all harness and sensors and everything are good. Put it on the computer and it said that the crank is not giving enough signal to fire. Wtf? Any idea?
