81 Trans Am LS1 / 4L60E
Finally completed my LS conversion on my 81 TTA. After a year of collecting parts and working out details the car is 98% complete. We removed the panels and doors and did a complete repaint…from burgundy to Daytona Sunset Orange. All front end parts removed and powdered coated. In came a LS1 and 4L60E out of a 98 Trans Am. Relocated the AC compressor to the top, dirty dingo brackets and clamshell mounts. Used 4th gen radiator and fans. Custom engine harness with 99 computer and a Spectra fuel tank with built in fuel pump.. Speedhut gauges to work with the new electronics. Conversion kit for the original shifter. Changed rear to 3.42 from 3.08 with new suspension. Wilwood brakes on the front. All new steering and suspension on the front.
The car is almost done, I have a power steering line that is leaking due to a compression fitting that was to help modified the original line on the 98 motor. The fuel tank had a bad sending unit and had to be replaced, the AC is not working and we are having to track down the problem. The in cress in power from the original 301 turbo is far superior and well worth the conversion.
For the power steering, consider just using a stock high-pressure hose for a 98 TA. My original LS1 engine came out of a 2001 base vette and I used a new PS hose for a 2001 vette. It bolted directly to my steering box with minimal bending (check my build thread). Your PS Box should have the appropriate metric fitting on it already.
