1966 C-10 5.3 Swap Build Thread
Almost finished LS swapping a 5.3 and 4l60e into a 66 c-10. Thought I would post up a few pictures.
1966 C-10
Came with a nice all white 5.3 sitting in the engine bay.
Checked and cleaned the motor and painted it a more tasteful color.
LS Simple Alternator and Power Steering Kit. Going to add the AC Later
Ready to go back in!
Found out truck Manifolds won't fit
Front Disc Brake Kit
Painting the Brakes
Engine in place with factory mounts with ls adapter plates
Front Disc Brakes
Master and Booster Intsalled
2001 Truck ECU
Summit Radiator and Fan Kit
Didn't Like the Stock truck hose so we modified the radiator a bit later
Battery Mount
Battery Mount
Battery Mount
Battery Mount Painted
Finished Mount Aerospace Optima Battery Holder
Red Top Optima Installed
Making the Air Intake
Fabricating new top hose location
Welded Tabs For Overflow Tank
Mr Gasket Coolant Overflow
Radiator Back in Truck
Modified truck hose looking much better
Air Intake Finished
Air Intake Finished
Sanderson CSLS1 Finally a header that fits!!!!
Driver's Side Header
Headers after a few coats of VHT Flameproof
What a mess!
Speedway LS1 fuel pump kit
1966 C-10
Painting the Brakes
Front Disc Brakes
2001 Truck ECU
Battery Mount
Battery Mount
Battery Mount
Air Intake Finished
Air Intake Finished
What a mess!
Cool build! What are your plans for a chassis harness? We offer one that currently comes with a $50 rebate. http://www.painlessperformance.com/webcat/10112
Thanks for all the replies. Basically have truck done waiting on hood latch and and hood springs to show up.
new vintage dash
Dash Wired
Truck has a dump bed so side exit exhaust
Lights off in truck
Lights On
Factory wiring cleaned up
More wiring
new vintage dash
Dash Wired
Lights off in truck
Lights On
More wiring
killer work.
you got way bigger ***** than me running 50 psi fuel lines inside the cab.
I think part of aging is you get more cautious about stuff like that, and I'm old now.
maybe a roll-over switch to cut the fuel pump?
not baggin on ya, just a comment. carry on with the progress!
killer work.
Got the headlights wired. Ended up just making my own harness since the oe is on back order. Hood latch and hood springs are now on. Just have a few bugs to work out. Since it is heating up outside we are going to go ahead and add the LS Simple A/C brackets to the truck now.
New Hood Latch
Hood actually stays up with both springs installed
New Hood Latch
Question, why didn't you just weld the top nipple on the radiator on the passenger side instead of the drivers side? I can tig aluminum and have done a couple. I just used a slug from a hole saw without the center drill as a piece to cover the hole left. Good looking swap and i like the LS Simple brackets.
