Lower Radiator hose ?
Old Mar 24, 2015 | 09:26 AM
49Willys's Avatar
Default Lower Radiator hose ?
Hi All
My project is 1949 ****** Delivery Panel that I'm swapping A LQ4 with 4L80E. I have a issue with lower rad hose and could use some well guided advice please. I have a couple of ideas but would lie to some other view points. I'm using the LS3/L99 water pump , I can take more pic if needed.
Thanks Dave
so not a lot of room to work with
could go with a straight neck and mod the rad with a 90 and move it out board
just to show how tight the upper is
Attached Thumbnails Lower Radiator hose ?-536276062lyyqdb_ph.jpg   Lower Radiator hose ?-wp_20150308_002.jpg
Old Mar 24, 2015 | 09:45 AM
JoeNova's Avatar
Restricted User
Straight neck is $25 from summit. Kinda looks like your best bet... I'm having a hard time seeing how you'll do this without cutting the neck off of the radiator and angling it different.
Old Mar 24, 2015 | 09:49 AM
49Willys's Avatar
The rad neck has to be cut and moved no matter what, make the necks straight with each other or straight water neck and use a 90 on the rad and a 90 hose
Old Mar 24, 2015 | 12:27 PM
DW SD's Avatar
Yes, I would put a 90 on the outside of the radiator tank. Suspect you might then be able to keep the 45 on the pump. Probably an off-the-shelf hose you could then use.
Doug
Old Mar 28, 2015 | 09:31 PM
49Willys's Avatar
well here is my solution
I think the water flow will be fine ?
some cutting and welding
I elongated the mounting holes in the LS2 water neck and used the LS3 thermostat it is a very tight fit
Old Mar 28, 2015 | 09:41 PM
76larkman's Avatar
I would think that would work fine. If need a temp guage sender spot you could put a bung fitting in when you weld aluminum to fill old hole. Oh on the upper if you had truck pump a chevy ssr (05) work more than likely. It worked really great in my skylark.
Old Mar 29, 2015 | 10:30 AM
ls1nova71's Avatar
That should flow water fine. My only concern is the hose being so short, it will be stiff and could put some stress on the radiator and possibly crack it over time.
Old Mar 29, 2015 | 11:10 AM
49Willys's Avatar
I agree with that but I have very few options with this layout, no mater how I look at it it's a very short hose. I will probably use a silicone hose to aid in flex at the radiator
Old Apr 3, 2015 | 01:20 PM
49Willys's Avatar
So here is the final setup and surprisingly the hose went on fairly easy. Thanks for the input
Old Apr 3, 2015 | 01:24 PM
DW SD's Avatar
looks great!
Who did the welding? Looks like a nice job.
Doug
Old Apr 3, 2015 | 02:49 PM
76larkman's Avatar
looks good, I would run it.
Old Apr 3, 2015 | 03:16 PM
49Willys's Avatar
A good friend did the welding for me, he' been doing it for a while
Old Apr 4, 2015 | 11:17 AM
Project GatTagO's Avatar
Nicely done.
Andrew
