Adding a 2014 L83 5.3 to a Jeep TJ any suggestions?
#44
Ok - so the power steering is now complete and working well. Next issue that I'm faced with is the trans shifter. I bought this from Speartech:
I'm having an issue mounting it to fit in the stock console. Are there any aftermarket floor mounted shifters available for the 6L80E?
#47
instrument cluster looks great...need more overall pics of the jeep and the engine bay show off your work man
I was curious about the speedo issue and just doing a google search it seems like this is a common issue with guys running e38 ecms so maybe this could be a genV ecm issue also? It sounds like it's something to do with something getting lost in translation on the can bus between the tcm and ecm if the bcm is not present. I don't recall but are you running a bcm?
#48
#49
I would think it would have to have some affect with the ecm not seeing the correct speed. It sounds like regarding the e38 ecms that there is a work around either with a vss setting in the tune or with running a particular vette tune/os that has a direct vss input into the ecm rather than over the can network. maybe something similar could be the solution for the direct injection ecm? there is a guy on here and maybe the hptuners forum (buddyholly) that seemed pretty knowledgable regarding gen IV swaps and I believe he ran into the same issue not sure if he figured it out though...might be worth hitting him up.
#50
#51
Just posted a new thread on the 2014 Direct Injection 5.3 ECM pin outs
https://ls1tech.com/forums/conversio...-pin-outs.html
#54
Ok - back to the 158 mph issue. I've been going through the wiring diagrams of a 2014 Silverado 5.3 and I've found that the serial data (High Speed Bus) goes through several different modules. As you can see from the attached picture there are 2 before the BCM and 3 after the BCM, but the interesting part to me is that at the end it shows a "Terminating Resister- High Speed Bus", maybe this is all that is needed to complete the circuit? Any wiring gurus out there?
#56
#57
Update.... I installed a 120 ohm resistor inline and now I have the correct resistance at 60 ohms. This DID NOT fix the 158 mph issue.
On to the BCM and a few other modules that I'm not sure of what they are, for example: the "Telematics Communication Interface Control Module" and the "Human Machine Interface Control Module"???? Anyone have a clue of what these to modules do?
#58
The Telematics one sounds OnStar related. Human Machine Interface sounds kind of science fiction-y. I really thought the resistor would help this, hopefully its the BCM. I envy your ability to stick with it, I'd have switched to a GPS speedo by now.
#59
I would switch to the GPS speedo but I'm very concerned about how it will affect the trans shifting and the ECM. I'm going to bleed the brakes today and take her out for her first
