4L60E Park Neutral Signal wiring, AGAIN.
Curious to know how this was handled by others with 4l60E's. (the wire that tells the PCM if the car P or N). I'm using a stock Camaro floor shifter and wonder if I can wire this to the switch on the side, or the plunger looking thing toward the front, or if I need to put the OE switch on the outside of the trans at the shift linkage. OR if there is a better solution.
Thanks!
Thanks!
What pcm & O.S are you using? Only the trucks need the PRNDL switch on the driver's side of the trans. I used a 2002 Camaro A4 tune file in a 411 PCM for the 4L60E trans/LS3 1968 Chevelle that I posted about. I just used the stock neutral switch for the starter & back-up lights. The Camaro PCM looks at the pressure switch inside the trans to determine what gear the trans is in.
Russ Kemp
Russ Kemp
I'm using a 99 T/A PCM. The car starts fine and runs great. It also goes through the gears ok, but it's still on stands.
So the only reason I may need the PRNDL switch is for back up lights? If that's the case I can continue to use the Dakota Digital gear indicator that has outputs for the reverse lights.
Car is a 75 280Z.
Got it covered. I cut the stock PRNDL switch off the Camaro floor shifter 'cause I thought I was smart (and saving room). BUT I'm using the Dakota Digital gear indicator indicator sending unit with digital gear display and it has a port for the wire in question AND the back up lights. Thanks for the help!
