ls1 swap ran fine now no spark no fuel
I've got a 72 c10 with an ls1. Been fine. Put over 1000 miles on it already. But I parked it last night in the garage. Went out today and it wouldnt start. Just crank. Fuel pump isn't pumping and I'm not getting spark. Relay is good. Pump works fine If I jump the relay but it still won't start. Cam or crank sensor? I don't know. I would trace it all down but I've been very busy with other vehicles.
All fuses are good. Checked continuity for the ground on the relay that comes from the ecu. Good grounds. Pump is grounded. Ecu is grounded. Have 12v to the relay as well. All fuses are good. Only have 8 fuses and 2 relays in total.
