1972 Chevelle Concours 5.3/4L65E Swap
The ridetech stuff is going on the wagon. Full air ride. Got a good deal on the last parts I needed. Lower front strongarms and drop spindles. Lots to do! Looking forward to getting started.
I am guessing if I was going to do a cam swap, now would be the time to do it right? Any suggestions? This will be a daily driver that I can autocross from time to time. I did a bunch of research but cams seem to be all over the board. The motor only has 97K miles so I am not to concerned about having to pull the heads or at least I hope I dont need to. Just looking for a place to start to build up a little extra HP.
I was looking at a Lunati Cam that is used with the following info but could not see anything about it on their website.
Duration 214/218
Valve lift .555/.551
LSA 117.5
Its for a z06 but it seems like it may work. Its in great shape. Just no part #.
Duration 214/218
LSA 117.5
So how is this coming? I did manage to find a '70 wagon and I'm doing a bunch of research. A couple of the things I'm trying to figure out:
1) Fuel tank options? No one makes an efi setup for these tanks, but guys are using elky or coupe/sedan tanks. I think the elky could be modified to used the side filler neck or you could do the license plate thing for the coupe/sedan. Then there is also the B body tanks that seem to be popular, but I'm having a hard time finding recent entries on that. I'm thinking I"m not using the right search terms.
2) Brake upgrades. I've seen a couple posts about putting in 10+ discs on all four corners, but I'm still trying to find more info, specifically the caliper brackets necessary.
3) Suspension upgrades: there seem to be some out there, but not sure what way to go.
4) Oil pan: I'm keeping the VVT in the L96 for now, but not sure what my oil pan options are as I understand it, the pan has provisions for the VVT.
Overall I think I want it to look mostly stock, so I"m going with the DD speedo converter and probably an Edge Insight CTS that plugs into the ODBII
