lsa blower swap?
Old Jan 23, 2017 | 01:28 PM
  #221
samckitt's Avatar
I thought I saw somewhere the comparison of the two compressors & the truck one was bigger. Body of compressor that fits on new Holley bracket is smaller in diameter than the pulley, 4.1" vs pulley 4.4".
This is the one for the new Holley bracket
Old Jan 25, 2017 | 09:25 PM
  #222
01cherryreds10's Avatar
Well I went outside today to pull off my R4 Holley bracket off of my Malibu, and tried slapping in a truck AC bracket and compressor. With BRP mounts the compressor fits in there great. So great in fact, that I'm going to order the Holley accessory bracket spacers for truck, and figure out belt length, and water pump spacers for my fbody water pump and use the truck instead of an R4. It went in like it was made for it, pretty amazing. Thank you for bringing up comparison to an fbody it got my *** out in the cold to problem solve.
I can get some pics during the day if you'd like. I took some with a flashlight but they turned out like crap. Wish the GM low mount would work on my Impala.
Old Jan 26, 2017 | 08:33 AM
  #223
samckitt's Avatar
You doing this all with a supercharger?
Old Jan 26, 2017 | 10:26 PM
  #224
no sorry this will be getting a turbo after power tour. I was just letting you know truck ac will fit in this car with brp mounts. I would have to guess that setbacks should let it fit as well. Also would think ctsv/c6 should be pretty compact
Old Jan 31, 2017 | 04:24 PM
  #225
97TA95Z's Avatar
Default Alignment pin jig....
Any chance I could pay a rental fee to use someone's LSA alignment hole attachment? I'm throwing one on an Ly6.. I'd really appreciate not having to spend 180$ on it.
Scott
Old Jan 31, 2017 | 04:49 PM
  #226
wyattroa's Avatar
I need to figure out if this would be a better way to go then a single turbo setup. It will be going in my 66 chevelle. So many choices to make when building a car.
Old Jan 31, 2017 | 06:18 PM
  #227
ryanleiker's Avatar
This is the delima I've been facing since I finished my turbo setup. If you can get one of the pulloff superchargers, the money will be about the same as using a Chinese turbo. If you run a high dollar turbo, and a new supercharger, it still might be cheaper to run a turbo. Fabrication and engine bay simplicity is sort of the deciding factor for me. I'd like a simpler engine bay but that's why I'm planning low mount twin turbos (hopefully).
The ceiling on power level is pretty established with the LSA, but a turbo could go as high as you want.
Old Feb 3, 2017 | 11:22 AM
  #228
b00sted04's Avatar
Are you able to use the stock lq4 valley cover, or would it need to be changed.
Old Feb 4, 2017 | 12:50 AM
  #229
gofastwclass's Avatar
There is no better or worse, only different. You are talking about two completely different animals. You need to decide what your goals are for the vehicle then factor in what your wallet and fabrication skills will allow. No one can answer these questions but you. Parts availability will also be a factor as the used LSA supercharger market is not what it once was. Once you have the goals and limits sorted, the choice will be clear.
The stock Gen III valley cover works fine, but the crossover tubes need to be LSA style for best fitment.
Old May 6, 2017 | 10:36 AM
  #230
SC_Titan's Avatar
Great thread. I've got an ly6 I'm putting into an 86 C10.
I'm trying to figure out the best sc drive/acc bracket setup that will:
1. let me overdrive the blower
2. Retain A/C
The LSXconcepts race drive plus high mount ac and ps/alt brackets look like it would work but is going to be $1000+ in just brackets. I do have all the 08 truck accessories if any can be used. I know I will need an ls3/lsa WP.
I saw Pocket found the stock lsa sc drive for ~$100 and used eBay corvette ps/alt bracket. Not sure how I would make ac work with that?
Any suggestions?
Old May 6, 2017 | 11:28 AM
  #231
LSXConcepts's Avatar
2. Retain A/C
Any suggestions?
Well if you want to run High Mount A/C and run the supercharger on a 8 rib belt, there are not a lot of choices. If you have any specific questions about the LSX Concepts parts Ill be glad to help you. and if your interested we also have a new Gilmer Drive that supports High mount A/C
Old May 6, 2017 | 04:45 PM
  #232
Ford_Assassin's Avatar
I am running Olson stuff...
http://www.okw-inc.com/Products.html
Old May 6, 2017 | 06:15 PM
  #233
SC_Titan's Avatar
Your race drive is on the short list. Has anyone reported belt slip with it? Gilmer drive is cool, but seems overkill for my weekend cruiser.
Old May 6, 2017 | 06:17 PM
  #234
SC_Titan's Avatar
Olsen looks quality. Appears to use 6 rib. Thanks for sharing.
Old May 6, 2017 | 06:29 PM
  #235
Haven't had any complaints on belt slipping, The only real complaint I have had a from a few guys telling me they broke their transmissions because they made to much power.
Old May 7, 2017 | 07:10 AM
  #236
casias's Avatar
I'm running 6-rib without any noticeable belt slip. I am using a Goodyear Gatorback belt.
Pictures purely for attention. Last picture shows belt arrangement, but belt was way too long in this picture.
Old Jul 29, 2017 | 04:21 PM
  #237
b20forlife's Avatar
I'm thinking about buying the Olsen kit and putting it on my c5. Any ideas on how much power the blower will make on a stock ls1?
Old Jul 30, 2017 | 03:28 PM
  #238
Project GatTagO's Avatar
So I have read this whole thread and I think I have a handle on what will work for me. I am thinking about getting one of these blowers for my Cougar with a LH8 5.3L...
I currently have a Corvette balancer, LS2 Corvette water pump, Holley alternator bracket on Corvette spacing, no PS, no A/C. From the reading here, I should be able to retain most of it, install a LSA balancer, get the various LSA blower drive tensioners and idlers, and good to go? Am I crazy?
Also, how badly do y'all think the ASA cam would be with a blower...:-)
Andrew
Old Aug 2, 2017 | 06:36 PM
  #239
bodybyvic407's Avatar
Originally Posted by ctsvcaddy
Received the new bracket today and test fit it. Everything looks good and lines up. As soon as my heads are done the blower is going on.
Are these still available? Street performance number says out of service when you call. Looking for a high mount ac relocation for an lsa blower.
Old Aug 2, 2017 | 06:53 PM
  #240
Street and Performance went out of business last year, the owner died.
