5.3l absolutely no power???
Old 05-06-2015, 12:38 AM
rfoster23g's Avatar
Default 5.3l absolutely no power???
Hello I really early swapped a 5.3l from a 03 avalanche into my car with a t56 anyway the swap is now running and is drivable but it has absolutely no power what so ever. I'll I can really do is idle it through each gear when u Rev it is very slow to climb in ram and the higher the rim the less it seems to pull. The strange thing is it idles awesome no misses in neutral and you can Rev it up and it responds very quick and sounds clean. The only thing is I have open headers on it and I know I need to put at least 18 inches of pipe for the o2s but that wouldn't kill the engines power like that would it? Also I have verified I have correct fuel pressure at 55psi and I threw on a brand new map sensors. Any ideas? Thanks in advance
Old 05-06-2015, 12:52 AM
truckdoug's Avatar
any codes? sounds like "limp home mode" maybe
Old 05-06-2015, 05:30 AM
rfoster23g's Avatar
No I haven't checked it yet but I will find out this afternoon but last time I checked there was nothing
Old 05-06-2015, 06:27 AM
gagliano7's Avatar
Hard to say but I have read a lot of people having problems with open headers and the 02's. Put a piece of pipe on and see if that works.
Old 05-06-2015, 06:35 AM
lsxRanger94's Avatar
I know you checked fuel pressure, which you probably did in the driveway. Did you check it while driving? I've seen fuel pumps pump ok when sitting in the shop, but take a nose dive when the rpm comes up.
Old 05-06-2015, 07:08 AM
rfoster23g's Avatar
To answer your question no I haven't checked it while driving but I will. Though I did check it in while holding the rpm up and it seemed to hold steady and come up when revved
Old 05-06-2015, 11:01 AM
aknovaman's Avatar
Clogged injectors.
Old 05-06-2015, 11:35 AM
rfoster23g's Avatar
Well I recently pulled of the rails and soaked all the injectors in seafoam for a couple days when I was hunting a missfire at idle. And they looked great before I soaked them but the car seems to idle perfect and Rev in neutral without protest. It just seems to have no power at all when trying to pull
Old 05-06-2015, 12:54 PM
aknovaman's Avatar
A datalog would help if you can find someone with HPT to take a look.
Old 05-06-2015, 03:41 PM
rfoster23g's Avatar
Don't know anyone with hp tuners but I did check the codes and I have one pending codes with is a po332 which is a knock sensor code could this be caused from open headers?
Old 05-06-2015, 03:42 PM
rfoster23g's Avatar
Also hopefully can get some exhaust on this thing sometime this week
Old 05-06-2015, 03:44 PM
Tranz Zam's Avatar
A bad knock sensor would cause issues with drivability.
I ran LS engines open header before I could get the exhaust done and they ran like total ****. Getting the exhaust on helped 100%
Old 05-06-2015, 09:16 PM
aknovaman's Avatar
Where are you located?
Old 05-06-2015, 10:55 PM
69rat's Avatar
i have a question for anyone who can answer it which may be related to this topic. if the swap that he described is done,(lm7 engine that now has a manual trans rather than 4l60e) will the pcm need to see an input for the trans in gear to operate? i assume the pcm adjusts timing with input from the MAP, and is possibly not adjusted because of no input or lack of a tcm? any thoughts?
Old 05-06-2015, 11:24 PM
rfoster23g's Avatar
Thanks for the feedback guys!! anyway I am located in Chattanooga Tennessee and the only tuner i know of is about 30 min away and hes booked up for a couple months so looks like I am on my own lol. Anyway when I got my computer flashed this is what the tuner at lt1swap.com said."vats removal is no problem. manual trans, and performance tune for stock engine all no problem." so i think he supposedly took care of it.
Old 05-07-2015, 09:21 AM
aknovaman's Avatar
The engine will run fine without a trans or tcm attached, electrically. Likely he shut off all the trans codes if he kept the automatic file. He really needs a data log to see what is holding the motor back. It could be anything from a faulty engine coolant sensor, bad tps or low fuel flow under high load conditions.
Need more data before changing any parts.
Old 05-07-2015, 12:07 PM
rfoster23g's Avatar
Could I possibly data log with this http://m.ebay.com/itm/400488079883?nav=Search
Old 05-07-2015, 01:35 PM
aknovaman's Avatar
No. I have tried those and over half of them never even function especially the Bluetooth ones never connect to the car. I still recommend a data log with hptuners or efi live so you can really see what is going on with timing and fuel and see each sensor data being fed to the PCM.
Old 05-07-2015, 02:02 PM
1964SS's Avatar
I've never had an issue with the ELM bluetooth adapters. They are awesome, but they aren't for data logging.
Old 05-07-2015, 02:36 PM
aknovaman's Avatar
Where are you getting the elm devices. I have a 50% pass rate on them. The do show up on Bluetooth and pair but don't connect to the buss, serial and can buss.
Quick Reply: 5.3l absolutely no power???
