Help identify my driveline issue
https://www.dropbox.com/s/jktxnue8l0...20001.mp4?dl=0
Things that i have changed are
removed supercharger from car (was worse with more hp)
driveshaft- swapped with a friends car
all rear control arms and added solid bushings all around
gears, clutches, spider gears, everything in the rear end other than the pinion bearing race and the actual carrier which i bought used from a 2011 mustang to fit the strange 31 spline axles.
wheels and tires from et streets to some street tires on cobra wheels
had car on dyno, was able to make a full pass without the supercharger, not with it though.
no issue in reverse only in forward gears.
sorry for the long post trying to cover all the stuff i have been through.
Have you checked the pinion angle and engine / trans angles? There is an app, perhaps spicer makes it to check driveline angles.
I'll rule out u-joints since you said you swapped driveshafts.
Does the transmission yoke engage sufficiently deep enough? I believe you need several inches of spline engagement minimum. On my 6L80 + L92 swap, I initially used a TH400 yoke. It was much shorter than the 6L80 but of the right diameter and spline count, and I had significant vibration just running on the lift. I picked that off before getting on the road.
There is a bushing in the tailshaft housing that could be worn. The yoke rides against the bushing. If the bushing is worn, the driveshaft could wobble while spinning.
Doug
project- i agree that there is a problem forward of the drive shaft that is the culprit i am just trying to pinpoint that issue i am interested in your thoughts as to what internally in the 400 could cause this. I had my transmission builder over this evening showed him the video, he believes that this issue could not be from the trans or converter. I am not sold though. in his words the clutch style carrier can not hold the power... my argument is my old motor made more power than this one naturally aspirated and had no issue at all 100k miles and all stock. i have seen many high hp cars with nothing more than what i have in the axle. I am willing to bust out the cc but need some clarity on what i am working towards.
here is my plan buy a $450 ptc spragless converter to eliminate that as a possibility. if that is still not it i will buy another 8.8 axle or pull one from a friends car that has a spool 35 spline axles and is known good. please keep the ideas coming I have to make it down the track!!!
Been doing cars for a long time.. WTF is a drive shaft "spacer"??
What's that loud clunk noise? The vid only showed a few revs of the d/s, and I heard that clunk several times. If that's what we are looking to cure, I'd be looking for 2 parts slamming into each other, as the assy rotates.
the loud clunk is something in the driveline like i mentioned i have rebuilt the axle many times as well as changed driveshafts
https://www.dropbox.com/s/762nli2xc9...R0026.MP4?dl=0
Item #ST-5557705 <--- google this. this is a driveshaft spacer... mostly used for swapping a c4 or tremec into a mustang.
I have inspected the u joints and you can not rotate the u joint to make it contact- the space between flanges is great enough this is not physically possible.
it feels like the issue happens between the flexplate and the tailshaft. something like the transbrake solenoind randomly clicking on and off/ during a wot pull it switches on off very rapidly that causes the trans to stop and start rapidly then transmit this through the driveshaft and axles the end result being the wheels hop.
Just looking at the video the driveline angles aren't that extreme. I still say it is something in the trans, but I don't know anything about automatic transmissions, so I can't really say what it might be.
Andrew
I went to go get e85 last night in my car. it did not shake from a roll in 3rd on the highway, did not shake in first and actually hooked, only had an issue on the 1-2 gear change. it is so inconsistant it is frustrating.
