L33 compression test, 130 all across
I did a compression test on my L33, all 8 cylinders shows 130. Shouldn't it be higher since L33 has a higher compression ratio? The engine was warm up prior to testing. There are no check engine light, car runs good, doesn't burn any oil, it just seems like these number were a bit on the low side. I spent all day searching n peoples compression test varys from 140-160. Could it be that the motor is on its way out? Thx guys.
Mod are: ls6 cam, ls6 intake, Hooker shorty.
Since they are all about the same, it could just be the gauge. Try another gauge. One that's known to be good,
What year? Was it a true L33 or a newer alum 5.3? Sure you go the cam installed correctly? Did you degree it?
Very odd all cylinders would be low. Tired engines usually don't wear evenly. Usually 1-2 cylinders will be low while the others were high.
It's a true L33, 799 head stamp on it, the cam was installed by the previous owner. I have no idea how he does it. I will re-degree the cam since the motor is coming out anyways for a auto swap.
