Turbo Gen4 Tubbed 72 Nova -()()
Old 10-03-2015, 02:20 PM
chevellepowered's Avatar
Default Turbo Gen4 Tubbed 72 Nova -()()
All aluminium Stock gen4 5.3
Arp head bolts
Mls gaskets
comp valve springs
Stock cam -for now
holley 1800 pump
8an feed 6an return
80lbs injectors siemens deka -e85
Edellbrock Intake & rails
Ebay throttle body
Ms3 Goldbox
Th400 Built
Ptc convertor
Ford 9"
Comp Turbo 7879
Truck manifolds modified
2" crossovers
Cranked it up , i forgot to to ground the ecm , burnt up injector driver , two of them , Mike at efisource was nice enough to fix it for free ,very pleased going with gold ms3 .
Ecm will be back in 2 days ill tune it abit and put it on a dyno .
Old 10-03-2015, 02:24 PM
Headers i made in spare time , never know when might wanna go procharged
There bbc headers from first gen camaro . 2" primaries .Bit over kill but what the hell ..
Old 10-03-2015, 07:37 PM
Baynut's Avatar
Very nice pal!
Old 10-06-2015, 03:23 AM
Jimbo1367's Avatar
In the one pic, the Nova looks to have a VERY NICE paint job. Any other pics showing the paint better?
Old 10-06-2015, 03:05 PM
Bought the car as a roller , already tubbed . caged etc . I will upgrade to disc in very near future , winter time is upon us shortly , money gets tight . Hvac tech . Paint is nice for what i paid for the car , has few chip here there nothing major . Might paint car later down the road . heres the shots From the hot side a lil better view
Im waiting on wastegates to get here, using two of them , 38mm . Dumped into atmosphere
Old 10-06-2015, 03:14 PM
Vbands are grooved ,slot in them for better seal and alignment . Got the Ecm back , plugged it in , bammo same thing again , burnt up two injector drivers . Spoke with him over the phone , great guy . Going to run it directly to the battery next go around instead of the starter cable . Didnt know these things were so sensitive voltage . So itll be next week , and going to install fresh battery , just so i cover my *** on all sides .And new battery cable ends etc . All i left to do Is drain line for turbo , feed line turbo , tuning it ,
Old 10-06-2015, 03:24 PM
Old 10-07-2015, 05:02 PM
hookemdevils22's Avatar
nice. this thing will be a screamer. what battery switch are (were?) you using through the tail light?
and don't let the 64-65 guys con you into believing they're a separate gen from the 62-63... the 68-74 are 3rd gen.
Old 10-07-2015, 07:00 PM
The battery switch was in there when i got the car , but my cuzzin says its outdated for the track , so ill to change that out to , to keep up with tech .
Got the wastegates in today, Cut the holes out , ill weld them in tomorrow and run vacuum lines
Old 10-07-2015, 07:01 PM
Emursa 38mm
Old 12-30-2015, 05:44 AM
kainedogg's Avatar
Any updates? Nice build so far.
Old 01-22-2016, 09:54 AM
Yeah i ran the car around town on 8lbs spooled instant with 3600 stall . Sold it , bought a 2009 rcsb silverado im doing v8 swap and big single turbo .
