67 Skylark Convertible
Old Oct 4, 2015 | 03:34 PM
Cyrperformance's Avatar
Default 67 Skylark Convertible
Started on this a couple weeks ago and figured it was time to put it up here. 67 Buick Skylark Convertible, original 300 V8 with powerglide going with 5.3 LM7 and 4L60E swap.
Old Oct 4, 2015 | 03:52 PM
1989GTA's Avatar
Signing on for the build.
Old Oct 4, 2015 | 04:48 PM
Picking up
That's some sweet interior!
Lovely, incorrect frame mounts welded to the crossmember.
Old Oct 4, 2015 | 05:03 PM
48 year old technology needs to go!
Old drums and upper A-arm out and new UMI uppers in.
New disc conversion front kit in.
New rear disc conversion kit in.
Old Oct 4, 2015 | 05:50 PM
Old Oct 4, 2015 | 06:36 PM
67Skylark's Avatar
Nice start, The brakes will make as much difference as powertrain. Cool looking intake.
Old Oct 4, 2015 | 08:01 PM
Alwhite00's Avatar
Looking great, sharp body style.
Old Oct 4, 2015 | 10:19 PM
Unfortunately the stock rims did not fit the rear so had to throw a set of 15" rims and tires that were laying around until she is driving and a new set get ordered. Thanks
Old Oct 5, 2015 | 07:59 AM
Even Kevin's (the owner) son Logan wanted the hacked up interior out so bad he did it himself.
Old Oct 5, 2015 | 11:19 AM
Jimbo1367's Avatar
Nice looking rider. Kinda "pimp'in" interior though. LOL
Old Oct 5, 2015 | 05:31 PM
I never understand when someone does things to these types of cars that does not improve anything in anyway, just makes everything worse all around.
Old Oct 5, 2015 | 06:21 PM
67Skylark's Avatar
Where you at in Florida?
Old Oct 6, 2015 | 05:42 AM
1967BuickGS400's Avatar
Nice looking car. What oil pan did you go with? I had an aftermarket pan on mine with the engine set low my tie rod ends would hit the pan when trying to turn all the way.
Old Oct 6, 2015 | 09:00 AM
KHAND 67Skylark's Avatar
It didn't take long to clear it all out. Looks like it was going to be one of those "donk" pieces of garbage… but we are rescuing it. lol
Old Oct 6, 2015 | 09:02 AM
We are just south of Orlando…. Cyr Performance is in Davenport
Old Oct 6, 2015 | 09:06 AM
We just ordered a MAST LS Conversion pan..backordered for a week. We were going to modify a stock pan but this pan had all the measurements correct per their site.
We will update with pics as soon as we get it in.
Old Oct 6, 2015 | 10:51 AM
Look who joined the Circus, welcome khand
Old Oct 6, 2015 | 08:33 PM
67Skylark's Avatar
Oil Pan,
You may want to look at the Holley 302-2 pan seems like it the way to go these days. My is a modified f body, cause that's all they had back then, so many more choices now.
Old Oct 6, 2015 | 08:41 PM
The Mast pan is exactly to the dimensions I measured out with the engine mount adapters positioning the engine where it is. The Holley pan will still have issues with the inner tie rod hitting.
Old Oct 6, 2015 | 08:59 PM
67Skylark's Avatar
Cool, glad you found something that works, The Holley is 1.25 deep at the tie rod area and the mast looks like 1.71, My F body is 1.375 and it still took some work to get the RH inner tierod to just rub. Of course lots goes into this, engine height, drive line angle, steering parts and how far forward your engine is placed, no one answer for all swaps. I'm thinking about doing the Holley pan, my is really tight and if I stand on the brakes I can empty the pan and loose oil pressure for a few seconds. Holley pan has a baffle kit that is plug and play. I'm headed to Canada for a few weeks but if it is still in the shop when I return I may try to run over and take a look at your work.
