Which A/C compressors are variable rather than on/off with a clutch?
Old Oct 28, 2015 | 09:56 PM
FastKat's Avatar
Default Which A/C compressors are variable rather than on/off with a clutch?
So here's where I am at: The A/C compressor on my G8 is whirring and growling. I think it's on it's last leg. A replacement is north of $400... I think. Most discount retails have it for around $500. The G8 is an Australian car and low production so I get why it's so expensive.
Here's the catch - I believe the G8 compressor does not use a clutch to turn the compressor on and off. It uses a PWM system (pulse width modulator) to control how much the A/C compressor actually pumps. Instead of being all on, all off, it is variable.
With that said, what other GM LS compressors are variable and use PWM control? The G8 uses the "Corvette" spacing. I have heard talk of trying to switch in an LS2 compressor but nobody has done it, and I don't think it will work anyway because I think that compressor is clutch controlled, not PWM controlled.
Any help would be great! Otherwise, maybe a used compressor?!
Old Oct 28, 2015 | 10:20 PM
sierravmax's Avatar
98-02 Ls1 Fbody's came with variable compressors and they have clutches. Your compressor should still have a clutch to disengage it for when not in use, high head pressure, and loss of charge situatuons. Have you tried checking Rock Auto or trying to find someone that offers rebuilt models? Also make sure to replace the drier everytime you replace a compressor.
Old Oct 28, 2015 | 10:31 PM
sierravmax's Avatar
I found this, but they are used. http://m.ebay.com/itm/08-09-Pontiac-G8-6-0L-AC-Compressor-63K-OEM-/361415940099?nav=SEARCH
Old Oct 28, 2015 | 10:38 PM
FastKat's Avatar
Thanks! Yea, I know there is the used market. I just don't know how much trouble it will be to put it on. If it's a PITA then I'd rather get a new or reman. I found a reman for $391 shipped on eBay.
I am planning long tube headers next week so now might be the time to do it. If I replace it before it grenades, do I still need to change the drier? Why or why not?
Regarding the clutch, I am not so sure. If you look at all of the LS AC compressors, the on/off wiring leads to the front of the unit where the clutch meets the compressor body, which makes sense for an electronically controlled clutch. On the G8 compressor, the wiring goes to the rear of the compressor body. Weird.
The car does have 187k on it so I can't really complain all that much.
Old Oct 29, 2015 | 08:07 AM
brawls43's Avatar
I've been messing around trying to find an AC compressor for my engine swap. My G8 compressor hits the engine mount. One thing I noticed is the G8 compressor uses a 3 bolt mounting scheme, and most of the other LSx compressors use 4 bolt mounting. So you have change the bracket to the engine as well. And it appears that the G8 uses the Corvette pulley offset.
Old Oct 31, 2015 | 10:24 AM
69 Ghost's Avatar
The all the early cars have variable compressors. That includes the vettes, camaros, and GTO's. I have a very good GTO compressor for $75 that has the ports in the same basic location. I bought it for my factory ac conversion but it does not clear my side frame. I believe all the ac locations line up no matter what pulley system you are using. It is the rest of the system that has the different spacing depending on the belt system you are using. PM me if you are interested or talk to P Joe.
Old Nov 1, 2015 | 07:13 AM
FastKat's Avatar
I think the G8 compressor is one step past a variable compressor. The early cars still use an on/off switch to run the compressor clutch, and then I suppose the compressor mechanically regulates the pressure. On the G8 compressor, the way I understand it, the wire that activates the G8 compressor is not on/off - instead it is a signal that tells the compressor how much to pump, etc. It is not regulated mechanically, but electronically.
Regarding A/C locations lining up - if you are talking about the belt location, I am pretty sure there are at least some differences across the 3 spacing setups. (Corvette, F-body, truck) I put a truck pump on my conversion (my LS powered Jag, not my G8) and I wound up going to the truck spacing (same as some 2010+ Camaro) so I could have a compressor that would sit far enough ahead to fit.
Old Nov 4, 2015 | 06:21 PM
KENS80V's Avatar
I have a G8 GXP ac compressor that is virtually new for sale if you are interested. $200 shipped to you. It came from a car that was virtually wrecked after leaving the dealer lot when new.
Sent email to you.
