C10/Trailblazer L33 swap
Old Dec 14, 2015 | 04:14 PM
sadie380se's Avatar
Default C10/Trailblazer L33 swap
I'm doing a L33 swap from a late 2006 trailblazer into a 78 c10,
My question is since the "TAC" is wired into the computer , how do I wire
The throttle pedal?
Thanks for any help
Old Dec 14, 2015 | 04:33 PM
76larkman's Avatar
You want the tach box, gas pedal and wiring in between them. Also engine pcm.
Old Dec 14, 2015 | 08:39 PM
sadie380se's Avatar
I have the harness , pedal & computer,,, there is no tac box on this trailblazer, it's wired into the computer...... So I'm trying to clarify if your saying get a whole different harness pedal & tac
Old Dec 14, 2015 | 09:23 PM
ls1nova71's Avatar
THe wires for the throttle pedal on a GenIV come straight out of the ECM. have you looked at LT1Swap? This is for a truck, but a Trailblazer should be similar. http://lt1swap.com/E38%20ECM%20Connector%20Pinouts.htm
Old Dec 14, 2015 | 10:57 PM
alowerlevel's Avatar
An '06 Trailblazer 5.3 would be a LH6, not an L33.
L33 is GenIII
LH6 is GenIV
Old Dec 15, 2015 | 02:57 AM
sadie380se's Avatar
It's most definitely an l33 , 8th digit of the vin is "M"
Old Dec 15, 2015 | 09:22 AM
ls1nova71's Avatar
VIN code 'M' is an LH6, like he said. L33 is a GenIII, you have a GenIV if it's from an '06.
Old Dec 15, 2015 | 11:26 AM
sadie380se's Avatar
Ok my fault , it's an aluminum 5.3 with the 8th digit m
Old Jan 15, 2016 | 08:51 AM
Dunningboy's Avatar
Default Underhood Fuse box Help
Does anybody have the pinnouts for the underhood fuse box on a 2005 5.3 Trailblazer /Ranier I need to locate the ignition wire coming from the underhood fuse box
Old Jan 17, 2016 | 09:57 AM
truckdoug's Avatar
http://www.lt1swap.com/underhoodfuseblock.htm
this is a 2000 truck, maybe similar?
