Jeep swap
I like the idea of the water pump for being different, I'm not aware of lifespan /durability pros and cons, but how fast can water flow anywhere, when it's regulated by a thermostat?
Just my thoughts, not slamming the idea at all, but you have so much power and gears (literally in spades).......That I would think that a pretty problem free/no worries/simpler/cheaper belt driven water pump would be way to go.
I would think better radiator/fan/s could be a great addition, (maybe you already got the good stuff)
I can deff see for a drag car, that only needs it for short passes, failures might not be as detrimental, but your out spending more time on a trail/wheelin' just being in a bad *** jeep!
How much hp are the pumps claimed to free up?
Will follow your build for sure
For slocaddy, my thoughts on trying the electric pump are this. When running the rubicon or other tough trails, my jeep is loaded down, the rocks reflect heat, the rocks prevent breezes from flowing through, often times I am on the throttle in 4 low and not getting much air into the grill or winching someone else with the throttle kicked up a little. At idle for hours, there is a lot of heat build up, thus the hood vents. On my jeeps I drill a small hole or two in the thermostat to allow some coolant to flow. I am not sure either about how long this pump will last. It's not my DD, so I'm not real worried about longevity. As to how much power it really free's up? In the hot summer, I think that once I turn on the a/c or crank on the wheel and use the p/s pump it's a wash. The cheapest way is the belt driven pump, no doubt! It's an expensive little experiment. The worse I can do is my best Beavis impression and say "Hey, this sucks!" and change back to the stock pump!
Plasma cut off rear bumper and mounts. Was a custom bumper mount system, not all bolt on. I'll leave the rear mounts loose because the genright tire carrier will need two bolt holes drilled once I drop the gas tank.
Got the engine and trans bolted together. Headers, motor mount plates and starter installed. Maybe tomorrow will be the test fit. Hey slocaddy! I have a 1957 Cadillac limo that may be my next project. It is the style that does not have the glass divider between the seats. Looking forward to seeing your project as well!
I used a smaller Auto meter tach since the stock tach won't work with the LS computer. Tucked the tach and oil pressure gauge right up next to the windshield pillar. Can't really see it from the out side of the Jeep.
Also if you are running a stock height TJ watch the clearance between the left upper control arm and the alternator if running Fbody accessories. I'm running Rubicon springs and added longer bump stops to keep the control arm from hitting the alternator. If I was to do it again I would use truck accessories. They are cheap and very available.
On my suspension it's a three link front so there is no left upper control arm! I will be checking clearances though. My concern is the oil pan.
I would suggest unbolting the hood and fenders. About 20 bolts and they are off. Makes working around everything so much easier.
That LS3 is going to be great.
I like the Howell harnesses over the PSI just due to the braided harness cover that Howell uses. I put the LS computer right under the brake master cylinder. On a TJ there is a nice bracket.
Are you going to have this running for the summer?
JIMB- I was trying not to remove the fenders! I may need to after all. The space under the master cylinder might work. Will first need to lay the harness out and see what I've got. That location had been used for my viair compressor. Been thinking of relocating it, so that may be an option. Thanks! Hoping to have it running soon.
The stock steering bracket could cause problems if you made your own motor mounts or bought a kit without them. The novak kit has a new steering shaft support bracket that gets welded onto the driv side motor mount. Pretty sure AA has the same thing.
Also, the headers from novak are made by sanderson. Nice quality and beautiful! Kinda odd in that they do not use a gasket at the heads, but use black silicone sealant. The collector uses a really thick copper gasket.
The steering shaft bracket I made from some steel I had laying around. Attached it to the motor mount on the drivers side. I made the motor mounts as the Novak's weren't available yet.
Yes it's better to plug in the crank sensor before bolting on the starter. Also it's nice to fab the exhaust so you can pull the starter with out unbolting the exhaust or header. I brought the left side exhaust from the header around the front of the oil pan, using a 2:1 merge with the right side into a 3" cat. Then the largest 3" Flowmaster muffler I could fit to a 3" tail pipe. All mandrel bent tubing cut and welded as needed. If I was to do it again I would run two 2.5" cats then into the merge to the muffler for better flow. Also 1.75" shorty headers. The 3" tail pipe meant for a Grand Cherokee. It fit with some rework.
Plus...the oil pan still would need to come off to drill a hole for the dipstick.
It looks like there is room for the electric water pump. There is room on the passenger side inner fender to mount the ECM. This would let me mount the air compressor under the master cylinder. This is a very closely mounted engine swap. There is little room for error and I am glad I did not have to fab these myself. My hat is off to those of you who did it all on your own!
Folks! The lighter weight of this combo is noticeable! There is an 80lb difference.
JIMB- Thank you again! Prepping the collector gaskets sounds like a good idea. My plan on the exhaust is to build it with flanges in specific locations so I can remove it as needed. I have 2 cats that are 2.5 inches (hi flowing) and a merge pipe that exits at 3 inches. The muffler is a Solo Performance "Stealth" model. They have a resonator that I purchased a swell.
I know! It's an LS let it be heard! On the trail, I need to hear my spotters! On the street I have this uncanny urge to screw with mustangs, Hondas or any victim! Just straight line stuff, no corners! Everyone knows that jeeps are geared low and just aren't that fast!
